LRP SXX TC SPEC
#106
#107
#108
Last 2 days I was using SP 4.0T, but when I started using SXX I was using X11 4.0T and Feigao 4.5T. This was when my lipo started to swell. My batteries are mostly Intellect IP 5000mAh 30C. I m using 6mm high quality bullet connectors. My setting initially was the factory preset 1,4,1,1 then I changed it to 1,4,0,0 which suits my driving. FDR was at 8.7-9.0 (depend on which motor I m using ). Motor temp was around 75C for the SP and around 88C for the X11. I m running foam on asphalt technical with long straight outdoor track. The track (my country ) is in equatorial region with hot and humid tropical environment (30-38C). My car is TRF416WE. The SXX never cut off due to overheat, the highest temp that I encounter was 5 blinks.
#110
Whats the stock power cap rated at?
#111
lipo
Hi,
Can anyone tell me if it's possible to drive Lipo with a SP 3,5t motor?
On the box is told that max is 3,5T on 7,2v but also for Lipo?
Grts
Grts
#113
Can anyone help out with this? Trying to get a new SXX set up for a race tomorrow, and having some problems.
I've got everything hooked up right, and have followed all directions.
When I try to set up the radio by holding the Set button for three seconds, it never goes into the setup mode where you set full throttle, brake, etc.
The unit seems to power up, fan comes on, blue LED comes on, I'm able to get into the power profile setup, but that's it.
Thanks!
Thanks!
#114
How many times should the speedo flash (blue led) afther racing to be the best temperature for it, thanks.
#115
So my brand new, out of the box SXX isn't working. The problem is:
Intermittently, my car won't go from a standing start. If someone bumps me, it'll go and work ok for an entire heat. But, if I stop...it won't go.
I've tried different sensor wires, different cars, different motors. I'm very disappointed. I'm going to pack it up, ship it on my dime, and hope I get a working one.
#116
might just be a bad speedo
#118
#120
