LRP SXX TC SPEC
#46
sorry for the sxx thread redirect
i run 2 1/12 17.5 cars that are the same except the esc one has a comp 07 and other spx - i do not have the notes from test right hear but the comp say rolled at 80 the spx rolled out high 60's - trinity duo's 0 motor timing.
gear down on the spx and then gear down again and let it rip smaller the track more gearing down. love the spx - i will be buying more wanna sell?
#48
Running a 13.5, I ended up around 5.71 on a track a little larger than Fastlane. I'm running a SP 13.5 with the timing right in the middle (from the factory) for what it's worth. Once I geared down, the car came alive in the infield, and profile 7 really lets it rip on the straights, especially toward the end. On a bigger track, it could get scary. We're expanding in a few weeks, so I guess I'll find out.
#49
What is the main difference between the SPX and the SXX? Is one considered better or faster? Different purposes? Thanks.
#51
With this setup, we hooked up the fully charged battery, the esc came alive. we did the setup, it didnt work at first. so after checking the to do list we noticed we forgot to reverse throttle.
the second trial with correct setting, everything worked. Forward, brake. I corrected the servo hornas it was off a little I put the car on the bench and we were chatting with my friends getting ready to check the modes the ES started smoking and burnt.
This is the second SXX TC Spec that died on the bench and the 3rd to burn in this area and everyone has questions...
The only thing thats common with these setups are the spektrum receivers. or faulty ESCs.
I replaced the SXX with my spare and put a new Futaba HRS 27mhz PCm receiver and all worked fine.
I used the old TC spec with this receiver with no problems for the whole season last year. So my question is,
Is there a problem with SXX TC SPEC and Spektrum working together or I was unlucky and received a bad ESC?
Second is what do I do with it?
#52
Question regarding the Lipo cut off:
Does the whole car just shut down or does it leave you with steering?
#53
With regards to people discussing SPX vs SXX TC.
I see people saying the SPX has special advanced timing and profiles for stock spec that the SXX TC doesnt have and the SXX TC top profile not being as advanced as the top profile on the SPX. My question is, is it not possible to catch up by advancing the motor physically ? Or is everyone advanced the motors as far as they go already?
Ive just purchased the SXX TC you see and its all ready to go for tommorow nights racing, first time ive had a brushless system trying to find out a bit of info. What profile would you recommend? Im running 10.5 Vector.
#54
On high profiles you won't have high esc timing from throttle bottom but it raises dynamically timing when you've got full throttle - mostly on straights. So you've got great bottom end and also top end. With SXX and physical timing you can get only bottom end or top end not both.
I would use highest profile on your SXX for sure but it still will be lower than highest SPX profiles. Reason is - SXX is designed for mod where you don't use such high profile timing - motor has plenty of power. SPX is designed for stock motors to provide as much power as you can get from motor and even more.
#55
Higher physical timing won't provide what you get with SPX Stock Spec.
(when running 10.5)
#56
Suspended
Just got myself a Sphere Tc Spec, would any of you say i'd have seen a noticable difference had I purchased the SXX instead (10.5 class)
Also good to see you on here Richie T... see you tomorrow!
#57
I might not be coming down tommorow as i may end up going to Bedworth to set my car up for round 3 of the TORC this Sunday. Finally got some new kit, might be able to keep up with you n Bird down the straights soon
#58
Suspended
Yeahh he's already mentioned you have a sxx now, he must be getting worried
Hopefully i'll be giving mine a run up bedworth soon with greig on the wednesday nights... might see you there some time?
#59
Yer me and Russell had a chat about doing some of the Wednesday nights so ill probably see you down there one week. Do they get many people down on a Wednesday?
#60
Personally I ran SXX only with mod motors so I can't really compare these two. Sphere TC Spec and SPX is HUGE difference - mostly on straights.
