LRP SXX TC SPEC
Old 02-08-2010, 01:51 PM
  #136
Originally Posted by musti72 View Post
Hi everyone,
I want to ask if anyone had problems with their speedo when using Spektrum system on Futaba 3pk series. This year two national class racers were using the SXX TC and, one of them burnt it after running for 1 pack, and bringing it to the pit table. It was so confusing.
The other racer burnt it immediately after switching the receiver on for the first time, on the pit table. Afterwards he installed his spare SXX, and used original Futaba FM module/receiver, and used it without any problems.
Could someone please enlighten me, because I want to buy one.
Thanks,
Mustafa
I had problems with my LRP TC with spectrum but yesterday a driver had problems with his SXX ss.
Each time as he drove away, his speedo made a noise if it couldn't find his sensor.
mikky32 is offline
Old 02-17-2010, 04:05 PM
  #137
Originally Posted by DaveG28 View Post
Guys, what is the process for checking the temp check?
Mine says to press mode for a few seconds, but this doesn't seem to work, am I mean't to hold brakes as I turn it off beforehand or something?
With the switch in the off position, press the mode button and whilst holding it down, turn on the speedo, then you release the mode button. The set LED should start to flash ... start counting
chinaman is offline
Old 03-11-2010, 08:52 AM
  #138
some people said "tekin RS pro" was better than Sxx TC spec, is that true??
deadball is offline
Old 03-11-2010, 09:13 AM
  #139
dameetz's Avatar
In MOD class I think SXX TC Spec is better BUT in Stock class RS PRO is the best I think. I have both speedos BTW.
dameetz is offline
Old 03-12-2010, 11:04 AM
  #140
is sxx tc spec have to update for new firmware?? is there new firmware for sxx tc spec?
deadball is offline
Old 03-12-2010, 11:15 AM
  #141
dameetz's Avatar
Not that I m aware of, and LRP is not firmware update able at least for now.
dameetz is offline
Old 03-12-2010, 01:31 PM
  #142
Trader Rating: 37 (100%+)
Josh Keller is offline
Old 03-12-2010, 04:31 PM
  #143
The LRP SXX TC is for mod. You can drive stock with it like the Tekin but the Tekin has also stock software on it. The LRP will come to short.
For mod it is a very good speedo but for stock it's no match for the mamba Tekin advanced or the SXX ss.
mikky32 is offline
Old 03-12-2010, 11:02 PM
  #144
how stupid i am.... i use this esc for stock an the power so weak than others... how should i do?? sell this ecs and buy new Stock Spec?? i hope the stock firmware came out for this esc... i'm so disapointing....
deadball is offline
Old 03-13-2010, 03:59 AM
  #145
the stock firmware has already been released.. BUT it is hidden inside SXX Stock Spec and no one else except LRP has access to it
TC Spec is quite good actually, but you might have to set the boost to the max to keep up with the other stock spec ESCs. Remember, faster is not always better.
krat is offline
Old 03-13-2010, 05:58 AM
  #146
may i download and use it for my sxx tc spec?? i need the turbo.... because the turbo effect so hard to beat with sxx tc spec..
deadball is offline
Old 03-13-2010, 06:12 AM
  #147
nothing you can do with your TC Spec.
the stock firmware is buried deep down inside the Stock Spec..
the only thing you can do is sell your TC Spec and buy a new Stock Spec.
this is LRP's world..
krat is offline
Old 03-13-2010, 06:16 AM
  #148
deadball is offline
Old 03-14-2010, 09:12 AM
  #149
dodo's Avatar
have u actually dogfight or at least run head to head with the person using tekin RS pro? how different is your laptime compare to his?
curious to know
dodo is offline
Old 03-15-2010, 07:17 PM
  #150
sprintcarracer's Avatar
Trader Rating: 26 (100%+)
I just installed a sxx tc spec in my touring car with a 21.5, I run the vintage tran am. I have it on profile 10 with full motor timing and it has less power than the sphere tc spec that was in it last week. Is this esc only for mod or am I missing something.
sprintcarracer is offline
