Old 04-21-2009, 06:08 PM   #1
mark.t's Avatar
Default looking to get a xray t2 009 rubber edition
i want to get a team xray rubber edition to race with what are some thign that would go great with this car.
i will be buying alittle bit at a time so money isnt a problem right now.
what should i get as far as batterys motors esc etc.....
i am gettign the spectrum dx3s for my radio.
mark.t
mark.t is offline   Reply With Quote
Old 04-21-2009, 06:13 PM   #2
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Several sets of the correct tires for your application/surface are very important. Body choice is also important depending on application. Lipo batteries and compatible charger, along with a sensored, brushless motor and ESC combo would be great. Although initially expensive, they will provide you with the most amount of run time with the least amount of maintenance...
Do you plan to race the car? Carpet or asphalt?
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 04-21-2009, 06:20 PM   #3
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
If you are a novice driver or someone who just wants to pursue electric TC lightly, take a look at the T2R Pro. It is based off of the 009 but in lieu of the graphite is made of fiberglass among a few other minor component changes. However, the car itself is very much a T2 009.
You don't need to spend a lot of money for the "best of the best". Do your research and always work on your most valuable investment - yourself - through practice time and experience. Chances are, if you are a newcomer, you won't really fell the differences between a $300 car and a $450 car anyway
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 04-21-2009, 06:41 PM   #4
mark.t's Avatar
well i plan i racing mainily on carpet but i will do some asphalt (with a chaissi protector)
what are some good brands i can look into i want to get into this very heavily
and go pro soem day so i need to learn all i can.
thanks mark.t
Old 04-21-2009, 07:09 PM   #5
Danny-b23's Avatar
A good set of battery packs is essential. I like the SMC packs. The 4600's work good for my 4 cell 12th scale and the 4000 Li-Po works good for my touring car.
Touring cars in general don't have alot of room to put all of your electronics in. I would suggest getting a Low-Profile servo, and a micro reciever. This will leave you with a bit of room to put balancing weight, run a larger speed control, or tuck wires.
Danny-b23 is offline   Reply With Quote
Old 04-21-2009, 07:32 PM   #6
JimmyMac's Avatar
Where are you racing? And what class? And what are the rules?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-21-2009, 07:54 PM   #7
Dane's Avatar
Winning is not about having the right equipment as much as it is about driving skill and experience!
Old 04-21-2009, 07:54 PM   #8
mark.t's Avatar
i live in utah and i will race where the old apex hobby shop. i'm not sure of the rules i have never been in a race befor
but every one is way nice on utahrc.com
the class i will stasart out in will be the novice class till in can get used to it.
then i will go tc mod and maybe play with the good drivers
Old 04-21-2009, 08:20 PM   #9
JimmyMac's Avatar
Well find out the rules first. Then people can make suggestions for you like batteries and motors. No sense in buying a 21.5 if it's a 17.5 class.... etc, etc. Best thing to do is actually go to a race and see what everyone is running. Talk to the locals. The more you know, the better prepared you will be and the better your money will be spent.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-21-2009, 08:39 PM   #10
mark.t's Avatar
Novice 1/10th Scale Class:
any 1/10th scale chassis
No real motor rules
Any 6 Cell Battery or 7.4 li-po
Must be a novice racer
will be asked to move up as skills improve.
13.5 Rubber
13.5 Brushless Motor (13mm rotor is ok) or 19t Brushed Motor
Rubber Sedan Tires
7.2 Volt NIMH or 7.4 Volt Lipo
Min weight of 1525 grams
190 mm Chassis
5mm min ride height
Sedan Body
what are some good electronics that would work? that will fit theses specs?
thanks mark.t
Old 04-21-2009, 09:24 PM   #11
Fastforward's Avatar
I would suggest the Tekin RS speed control for your brushless motor. It is small and programable. It also has more punch than some other brands that I have run.
I have only run Novak brushless motors but I am sure there are others that are good. You might actually start out with a 17.5 motor as it will be easier to drive than a 13.5. Once you can run a 5 minute heat without hitting any boards then think about a faster motor.
I would higly recommend LiPo batteries for you car. I actually race with just ONE Thunder Power 5000 and I just recharge it after every round. Get a good charger, Thunder Power makes one, but there are others. If you are going to get a good car like an x-ray, get good stuff to go in the car.
Tires are very important. Jaco greens are popular for indoor carpet racing and outdoor asphalt up to about 70 degrees. As it gets hotter you go to harder tires (jaco blue, then jaco orange). Tires are important, find out what the local guys are running.
Get the xxx main chassis set-up book and study it. http://www.xxxmain.com/bookz.shtml
Remember to have fun, don't worry about going pro. That will happen if it is ment to be.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 04-24-2009, 08:38 AM   #12
bluephi1914's Avatar
Trader Rating: 34 (100%+)
mark.t
I have the t2 008 and love the Speedpassion 13.5 and speedpassion GT 2.0 combination... speedpassion is very agressive (punchy) i have also ran the orion 13.5 and love it also (a little more smoother)
I love my Sorex 28 's the best... I was running the jaco greens but i had to adjust the camber to get them to hook up and i dont like having to put my car on the setup board just for tires... i have also run the much more tires.. but the rims crack much to easy.
I am running the Spektrum dx3s and love it... i know a few people with the Furaba 4pk and they love it as well.
Battery.. I have SMC and Trinity Intellect Lipos... i love them both and hvent had any issues with them.
hope this helps!
Mr. 17.5 's Rides ----> T3 EU / T2 008 EU (Vintage)
** NEXUSRACING.COM **
** Team Xray - Team Novak - Proline - Sorex - KO Propo - Team Trinity **
bluephi1914 is offline   Reply With Quote
Old 04-24-2009, 08:44 AM   #13
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
If the class above novice is a 13.5 class... definitly start out with a 13.5, that way as you improve and are forced to move up a class, you already have a competative level motor. If you start out with a 17.5 just for novice, you will have to buy a second motor and you wont use your original at all.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
XRAY T2009 bola Electric On-Road 2679 07-06-2014 06:25 PM
