Old 04-19-2009, 12:45 AM   #1
Default Long Enough
Question to all, Im buying my first lipos for touring car racing (17.5 now and 13.5 future), will the Team Orion 2S 1P 7.4V 3400mAH 25C SLPB LiPo Batteries be sufficent for racing these classes using a Novak GTB spread spektrum esc or is there a better recommendation.
The chargers I have are the Tritons which charge at a max of 3amps for lipos, I already have two of these so they are going to have to be enough to get me started. The reason Im asking is because I have been to races where they race 7min qualifiers and 7min mains. Will 2 of these batteries get me through a day of racing?
Ron
RMP750 is offline   Reply With Quote
Old 04-19-2009, 12:55 AM   #2
rawfuls's Avatar
I would get a higher mAh rating if you're gonna be going long.
I usually keep all my LiPos within the 4k to 8k mAh ratings.
rawfuls is offline   Reply With Quote
Old 04-19-2009, 03:09 AM   #3
Hyde's Avatar
Doesn't track layout and gearing, temps, play a big part in how long you'll last?!
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 04-19-2009, 04:35 AM   #4
miller tyme's Avatar
Given the high cost but long life of lipo, I'd splurge and get at least the 4200-5200 mah rating and definetly 35-40C, the C rating DOES make a difference.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 04-19-2009, 06:42 AM   #5
Foxxrocket's Avatar
5000mAh or higher is where you want to aim. Especially with those 10 minute main races.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 04-19-2009, 07:48 AM   #6
Joel Lagace's Avatar
you need a charger with higher charge rate so that you can turn over the packs faster each run. I run my [email protected] 8amp charge rate. I run a single 4000 all race day long just hit with 8amps between heats...
But you shoulld be fine if you have 2 packs and keep up on the repeaks between rounds
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 04-19-2009, 12:31 PM   #7
Little_Mike's Avatar
i really like the ip 3800 and 5000, trakpower gold 4900 also very good choice, but the ip's have slightly better nummbers for charge results.
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 04-20-2009, 03:12 AM   #8
fly_wheel's Avatar
Ron
u should be able to run fine with ur batteries, recharge them in between races (if interval time is around 30 minutes)... no need for 5000mah unless u plan to run 2 heats with a single charge...
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 04-20-2009, 06:21 AM   #9
stiltskin's Avatar
Trader Rating: 102 (100%+)
I run an smc 4000 pack in 17.5. It drains about 1700 mah in our 6 min races. I agree with the charger recommendation. I run the same pack all day long. Good luck.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 08:35 AM
Not Another Car ....... FUK_WRX Australian Racing 56 02-28-2005 11:04 PM
What is the best way to break in a new ening? adsl Onroad Nitro Engine Zone 27 02-10-2005 08:49 AM
Marilyn Manson's Against All Gods Tour Switch Blade Chat Lounge 91 12-13-2004 08:21 PM
