Old 04-25-2011, 09:48 AM   #1006
Question, I just purchased the ball diff, does anyone know what spur gears are compatible. What I am looking to do is find a Metal spur or at least a heavy duty spur. The track has 2 areas that are just slick as all get out. I barely touch the throttle and I am spinning like a top! I am using the soft rears and tried different fronts. I have the rear weighted, front weighted and even had a guy make a custom weight for the center of the F10. Most of the guys are using their slipper as traction control, not to mention I think I am the only F10 left, So if I can get a better spur that would be great. Thanks!!!
Hpi Formula Ten - X-ray T1FK'05
Traxxas Slash - Traxxas Slash/LCG Slice Chassis
Come down to Englewood and Get your Race on!
www.sarcar-inc.org
Teknoron is offline   Reply With Quote
Old 05-12-2011, 02:05 AM   #1007
I'm using 48P AE spur gear (AS3923) on my F10
dimka_ff is offline   Reply With Quote
Old 05-12-2011, 10:27 AM   #1008
MikeR's Avatar
Trader Rating: 15 (100%+)
Interesting news for the HPI guys- the F10 finishes 1st and 2nd in the rubber class at the previous round of the UF1 Series! One was close to stock and the other was with the Exotek chassis. Pretty impressive considering how competitive the Tamiyas are.
http://charleslightfoot.com/UF1/results.html
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-12-2011, 10:44 AM   #1009
pejota's Avatar
Those are some interesting turnbuckles on that car in the top picture...
They change the caster?
pejota is offline   Reply With Quote
Old 05-12-2011, 12:07 PM   #1010
MikeR's Avatar
Neither cars were mine but I believe you are correct. As the tires move back that would give more neg camber as well, it appears, for more high speed steering which was a good move for this track we raced.
Old 05-12-2011, 01:43 PM   #1011
the car in the top picture is mine... yes the turnbuckles are for adding more caster. box stock the F10 tends to wander on the straights so i wanted to add more caster.
the improvement in handling is huge. that race that MikeR was referring to was the first time i raced an F10 (built two nights prior). in the first of three mains of the UF1 format i finished 5th, nowhere near the pace of the frontrunners. so for the 2nd main i made the turnbuckle mod using some trackside tools (cutters and a body reamer). that enabled me to mix it up with the leaders and ended up 3rd. then in the final main i was able to finish first.
the car comes stock with roughly 5 degrees of caster but after my mod it had about 15 degrees.
in that race i ended up 1st overall in rubber but my car wasn't the fastest F10 in the field. Hiro's car, 2nd overall (shown in the bottom pic) was still faster but had bad luck with traffic and pits. he didn't have the caster mod but he did have the Exotek chassis.
for the next race i'm getting rid of my silver can motor and installing an LRP 21.5. hopefully that'll let me keep up with Hiro's car.
T. Deguzman is offline   Reply With Quote
Old 05-12-2011, 01:45 PM   #1012
another view of my caster mod courtesy of the UF1 website.
Old 05-12-2011, 01:54 PM   #1013
the diff is also compatible with Kimbrough gears. they're also plastic gears but you can fit 12 diff balls instead of 8.
Old 05-12-2011, 05:03 PM   #1014
pejota's Avatar
Bravo on those links!
I had the F10 with the Exotek chassis.... i might have to get another one.
Old 05-12-2011, 06:30 PM   #1015
lightfoot's Avatar
Default Uf1 Series
This Saturday at Tamiya Track ( 2 Orion Aliso Viejo, CA 92656 )
UF1 Series continues with race #3
gates open at 8AM
Qualifying around noon
3 rounds of racing starts at 2PM
Control practice in the morning....
power will be supplied...
for more info :
http://charleslightfoot.com/UF1/rules.html
Love and Peace...
lightfoot is offline   Reply With Quote
Old 05-14-2011, 07:14 AM   #1016
Hey guys,
I've finished putting together my Fx10 with the exotech chassis and the yea racing upgrades, NOW i have a small problem where i'm trying to figure out what servo to use as i cant seem to fit my FLETA 3.0 ESC on the car :S i could mount it vertical but then i'm sure the f104 shell wont fit
Any recommendations on what servo to get and where and how to mount the ESC for better weight? Also any pictures would help
P.
pokiou is offline   Reply With Quote
Old 05-14-2011, 09:36 AM   #1017
MikeR's Avatar
Originally Posted by pokiou View Post
Hey guys,
P.
Any low profile servo like the KO2143 can work in this situation. Savox and Futaba make one also.
You can also just try adding some spacers to the ear so that your stock servo is moved away from the servo posts- hopefully this gets you the extra room you need for the esc. The body sits pretty high- you may actually be able to sit the esc on the side as well.
Old 05-28-2011, 06:29 PM   #1018
HeliYogi's Avatar
Trader Rating: 17 (100%+)
Default For the first time :)
Bring them out boys
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 06-02-2011, 10:30 AM   #1019
lightfoot's Avatar
Default Uf1 Series
This Sunday Circuit of the Americas ( Surf City )
4th race of the UF1 Series...
For more info....
http://uf1series.com/schedule.html
Love and Peace...
Old 06-02-2011, 09:08 PM   #1020
spring71's Avatar
Smile
Hello F1 Racers,
Check out the F1 rubber tires for HPI F10 from Ride & Shimizu.
Shimizu Grooved Tires, Click Here
Ride Slick Tires, Click Here
We have indoor RC Track & Shop in Chino, CA
For more information, please visit www.tqrcracing.com
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
You Know You're A Rc Maniac When.... Hulk Nitro On-Road 25 02-09-2010 11:23 AM
F1 Racing TimPotter Electric On-Road 501 05-29-2009 11:18 PM
GT Body Thread BlackKat Electric On-Road 11 03-08-2005 03:56 AM
