Old 10-05-2010, 01:36 PM   #781
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Originally Posted by Missle View Post
For me the only way to deal with this was to stop using the servo saver and using a strong-metal gear-digi servo. When the wall reaches out and grabs my car it rarely bends the steering arm a little bit.
i am running a servo that has metal gears and the tamiya HD servo saver. but Adam is 100% correct. add these stoppers and your issue will be solved.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 10-05-2010, 10:45 PM   #782
metalflakeking's Avatar
Just picked up an F10 and want to run a silver can motor with rubber tires and a lipo battery on an asphalt 60x80 track. Any suggestions on a fdr? Thanks.
MAX SPEED
metalflakeking is offline   Reply With Quote
Old 10-06-2010, 12:21 AM   #783
Indeed run a servo that has metal gears to solve your problem.
tonyhalandri is offline   Reply With Quote
Old 10-06-2010, 05:26 AM   #784
abailey21's Avatar
Trader Rating: 36 (100%+)
Originally Posted by inconceivable View Post
I used extra shims (about 8mm total) and a 3mm screw here but it still wants to push past (or over ?) this. May need to go with more shims or a "post" that is wider (girth) I suppose. Thanks.
Also turn down your endpoints, and dual rate
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 10-06-2010, 07:51 AM   #785
i usually start at a 4 fdr and run a lap, check temp, if ok, another, if ok, run 3 more, if still ok, let it sit, for about 15 min, then run for about 1 min on the track, check temps, if ok, run for 3 min, if ok run for 5 min. if ok, increase 2 teeth on spur. continue until the temp of the can doesnt get too hot. i personally dont like more than 90* on silver can. i dont know the max temp the silver can can sustain, but i think its higher.
i like an FDR around 3.5-4.
and the area of the track isnt a good refrence. if there are alot of turns, you want a higher fdr to get out of those breaking areas faster, but too high you can spin out and other racers can make up ground on the straight away.
Old 10-06-2010, 09:40 AM   #786
Thanks for the insiteful info. I will be the first person running one at my local track and hope to start a budget friendly spec class. They look like lots of fun.
MAX SPEED
Old 10-06-2010, 11:04 AM   #787
i remember about 2-3 years ago i did the same thing in tampa. I even got a brushless for mine from abailey1 and was at the local track for months on end. no one showed (for F1rc.
Several months later, i find out there is a class and there are 25+ people running in it!
Old 10-06-2010, 10:14 PM   #788
gsxr0311's Avatar
Trader Rating: 19 (100%+)
I know this is not a for sale thread, but I wanted fellow F1ers to get first dibs. I am selling my F1-09. If anybody wants I can post pictures. It comes with complete rolling chassis, stock foams, silver can motor, CRC update side springs, and a KO PROPO pds-2502 digital servo. $70. P.M. me if interested. Thanks guys.
Special Thanks to: RC Target, Ko Propo USA, A Main Hobbies-SWORKz USA, R1 Wurks, and Absolute Hobbies.
Capricorn: LAB-C802, LAB E801, LAB-C03, TE03, and P01 235mm. IGT8. SWORKz: S350BK1 EVO II, S104EVO, S12-1M. Top Rebel 12.
gsxr0311 is offline   Reply With Quote
Old 10-07-2010, 09:52 AM   #789
adam, did your fx10 kit come with 3x3 spacers or just 2 sets of 1x3? mine came with 2 sets of 1x3, one was standard alum washer and the other was a 1x3 spacer in a nice dark grey color...
i contacted mikeR just incase there is an issue...
Old 10-07-2010, 12:39 PM   #790
abailey21's Avatar
I honestly don't remember dude
K.C.C.O.
Old 10-08-2010, 09:17 AM   #791
Mike R said that it should have come with those spacers. hes sending them to me. GREAT SERVICE!!!!
Old 10-08-2010, 09:54 AM   #792
abailey21's Avatar
He's an awesome dude, I have my EXO104 in the mail as we speak. I'm looking forward to trying that as opposed to the FX10.
I just suck at setting up link cars, I've only run T-bars like the HPI so it should be interesting
K.C.C.O.
Old 10-08-2010, 11:10 AM   #793
Talking F10 upgrades
I have a HPI F10 with the Exotex chassis , HPI shock and ball diff , Yeah Racing one piece motor mount and axle upgrades. With the Exotex mini battery adapter I can use the F104 bodies which makes for a very cool looking car , works real nice to.
E M Motorsports is offline   Reply With Quote
Old 10-08-2010, 11:52 AM   #794
that it shall. best part is the exotek chasis are 90% of a complete chassis. The HPI really only needed the t bar, motor mount, servo arms and front/rear sus. everythign i already hopped up... so I technically have 2 chassis. one fully modded and one bone stock.
that F104 isnt very forgiving. its a great chassis, but I am like you, the link is a little more complex. but there are companies with rear pod shock upgrades that include 3 shocks on the rear pod instead of 1. probably better for rear stability...
Old 10-08-2010, 12:29 PM   #795
abailey21's Avatar
he Exotek uses the Yokomo R12 setup which is awesome
K.C.C.O.
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
You Know You're A Rc Maniac When.... Hulk Nitro On-Road 25 02-09-2010 11:23 AM
F1 Racing TimPotter Electric On-Road 501 05-29-2009 11:18 PM
GT Body Thread BlackKat Electric On-Road 11 03-08-2005 03:56 AM
