Old 09-24-2010, 04:44 PM   #721
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Team Lotus View Post
Ok, but that is an add-on that MikeR did; how does the stock front suspension work on this car? I see no way that it is dampened at all!
Knuckle is connected to the upper arm, upper arm is connected to the damper tubes. Lower arm is fixed and acts like a shock tower. The upper inner arm is the fulcrum point so actuates the damper tubes.
Try mocking one up and you'll picture it better. Pretty simple to rig up actually.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-24-2010, 04:44 PM   #722
inconceivable's Avatar
Originally Posted by MikeR View Post
It's true- they fit on the HPI Foam Axle conversion. The catch is the HPI rubber super softs are way better than tamiya Softs
I have the HPI super softs mounted on Ride wheels for my F104, this is what I mounted up on the F10. Very cool that I can use these now on both cars. So it stands to reason that you can also use F104 foam wheels and foams ? If so, what's the benefit of F103 foams over F104 foams ? Thanks !
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 09-24-2010, 04:48 PM   #723
MikeR's Avatar
I don't know- you'll have to let me know if you find out
Seriously though F103 rears are much wider (more grip!) and there are more compound choices for F103. Given time there should be more choices for the F104.
Old 09-25-2010, 11:09 AM   #724
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Wait... So f104 wheels fit the formula 10?!?!? i am having a horrible time finding tamiya foam tires.now, F104wheels/tires.... theyre eerywhere!
So... any F1 class in CFL? Adam... you know of any and what are the requirements. I found about 6 silvercan motors in my closet and i know that 99% of F1 classes uses them as the motor of the class.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 09-25-2010, 07:23 PM   #725
abailey21's Avatar
Trader Rating: 36 (100%+)
Hey Mike, any chance of some up close detailed shots of the dampner tubes. I think i have the concept down, but the angles of your car don't make it very clear.
It's something I think i'd like to try in the future
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 09-27-2010, 12:59 PM   #726
For those running 21.5 and foam. What rollout are you using ? After digging around various threads it seems like 85mm - 90mm is the range for 21.5 F1, but wanted to verify. For testing in front of the house, I'm running the 95T spur that came with the foam ball diff and a 25T pinion which is giving me about 50mm rollout. It seems fast, but is a far cry from 85mm ? Also, if 85mm (ish) is correct, what spur have you found to be best to allow for rollout adjustment as the tires wear ? Thanks !
Old 09-27-2010, 01:24 PM   #727
im doing the same but with a 24t and a silvercan.
Old 09-27-2010, 01:41 PM   #728
I have been thinking about going brushless 21.5 though.... anyone know the general rules about f1rc and motor/esc requirements?
Old 09-27-2010, 07:15 PM   #729
Airflow's Avatar
Hi, I have some questions...
Hope someone can help me out.
This is for my F109.4
- Is the F10's rear tyres the same height as the F104's?
- Can I mount the F10's rear tyres on F104 rims? Or I have to mod the rims?
Need to use more stickier rear tyres.
Im getting addicted to Formula 1 kits thats why Im buying an F10 kit soon.
Need to confirm some things...
- Whats the maximum ride height I can do with the F10? (building a street spec)
- What hop ups do I need to make it handle a 10.5 BL setup
- What are the weak points of this kit that needs to be addressed with hop ups
Thanks in advance
Airflow is offline   Reply With Quote
Old 09-27-2010, 07:32 PM   #730
Thanks in advance
10.5 bl is too much. and the max ride height is pretty high, and parts to upgrade are knuckles/diff (if you want to go foam)
ball diff if you want to keep rubber and shock.
the tamiya f103 friction pads fit/work with the f10.
Old 09-27-2010, 07:46 PM   #731
Airflow's Avatar
Im running 10.5BL on my 3Racing F109 (F104 spec) with rubber tyres
drag racing with M04s and M05s. So Im accustomed to the speed that
it brings, more fun than my 4WD TCs.
Thanks for your input.
How bout the tyres? Will they straight fit on a F104 rear wheels?
Old 09-27-2010, 07:55 PM   #732
no clue.
F1 is a different beast. Im used to 2.5 and 3.5R's but F1 is tough to control at that speed on rubber. foams will make it twitchy, best of luck on your adventure.
Old 09-27-2010, 08:32 PM   #733
Airflow's Avatar
I recently found out that using f104 foams up front and soft rubber tyres at the back makes for a "point and shoot" F1 kit.
Very stable at the straights and brakes straighter too.
Can anyone here who also has the F104 rubber tyres compare it with the F10's
tyres if they have the same inside tyre diameter?
Old 09-27-2010, 10:02 PM   #734
MikeR's Avatar
Yes, the long circled ball end swings inward when the arm swings up and so the dampener tube plunges inwards.
Hope that helps!
Old 09-27-2010, 10:21 PM   #735
Hope that helps!
what are the benefits of this?
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
You Know You're A Rc Maniac When.... Hulk Nitro On-Road 25 02-09-2010 11:23 AM
F1 Racing TimPotter Electric On-Road 501 05-29-2009 11:18 PM
GT Body Thread BlackKat Electric On-Road 11 03-08-2005 03:56 AM
