Old 09-01-2010, 10:31 AM   #691
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Mike, that is a cool video of an awesome night at Cal Raceway.
Too bad for me I was the other yellow car, down in second watchin you pull away!
Any chance you have the videos of the earlier races where we were locking horns for about 6 of the 8 minutes? (yeh, I had the 6 minute tire sauce that nite )
I remember it well, we were dicin back and forth and Ted Nugent's "Stranglehold" was blastin!
Heat before that Black Sabbath's "Paranoid" was rockin then into "Mississippi Queen".
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 09-01-2010, 11:23 AM   #692
MikeR's Avatar
Trader Rating: 15 (100%+)
Haha- yeah it was a great night of racing, especially the epic battle we had in rnd 2 that I unfortunately forgot to record
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-04-2010, 09:38 AM   #693
BrodieMan's Avatar
Got my Formula Ten a couple days ago and am really enjoying it. It's my first onroad car and I am loving the new challenge after running only my xxx4 for the last four years. I put my novak GTB in it with a little notch cut out of the chassis to fit it in. The steering linkage is not so great so that, S compound tires, and bearings are my first upgrade priorities. I have been running it with my Orion 3200mAH 7.4V lipos, they fit perfect, and my Velocity 6.5R motor which is a bit overkill but its all I have and by lowering my throttle exponential way down its actually manageable. They body is a bit weak/thin in areas and I ended up butchering it a bit but nothing major. A few things I don't like about it are the screws (Hex should be industry standard), The front arm shims are to easy to crush with the pivot balls, and limited space for electronics. Overall a great kit that I am looking forward to pimping out.
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 09-06-2010, 11:20 AM   #694
tha Beast's Avatar
Trader Rating: 100 (99%+)
im sure that this has been asked before but im new to F1 and to this thread but my question is has anyone raced the F10 against a Tamiya f104 and just smoked the Tamiya also does the F10 have caster and camber adjustments???
tha Beast is offline   Reply With Quote
Old 09-06-2010, 11:26 AM   #695
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 09-15-2010, 02:04 PM   #696
inconceivable's Avatar
MikeR - I like the mod you did to the front end using Speedmerchant damper tubes. Are these the tubes you used ?
http://www.teamspeedmerchant.com/sho...l/smr1422.html
I believe you would also need 2-56 grub screws for the tubes as well as 2-56 ball ends ? Could you confirm ? Do you have any close ups of this mod ? Thanks !
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 09-17-2010, 10:03 AM   #697
MikeR's Avatar
Yes, that's the part. I think it comes with the grub screw and ball cups- I think I actually used RC18T ball cups and this ball end (4);
http://www41.instantestore.net/merch...y_ball_end.cfm
Here's a pic;
This assembly helps to keep the front knuckles from locking up if you tag a wall by the way.
Old 09-19-2010, 06:23 PM   #698
lightfoot's Avatar
Default September 25th F1 race
Ultimate F1 Day
Saturday September 25th
Camarillo California , track opens at 7AM for practice
3 min , fast lap Qualifying 10:00 AM
3 15 minute races
2 mandatory pit stops
http://www.charleslightfoot.com/UF1SD.html
Raffle prize #1
Professionally built, F104 Pro, with Tekin RS ESC, Novak 21.5 motor,
2.4 receiver, Orion 3200 lipo, Shimizu rubber, Calvinization modification, custom painted F60 body from F1 Paint-lab...
Ultimate RTR F1... just bind to your radio and
go... estimated cost $920
Raffle prize #2
Tamiya F104 Ferrari Kit
Each racer will have their name placed in a container... after each race, if you did NOT receive a penalty your name
will be placed again in the container, increasing your odds of winning... Also after each race, the announcer and the
pit marshal will each choose one person who they felt was the cleanest driver of that race, regardless of how they
finished and there name will be added again to the container... Basically the cleaner you drive all day, the better
your chances of winning the prize Also, in case of a tie, the driver with the least amount of penalties win...
Love and Peace...
lightfoot is offline   Reply With Quote
Old 09-19-2010, 06:33 PM   #699
Airflow's Avatar
Hi, can I fit F10's rear tyres into F104 rear wheels?
Airflow is offline   Reply With Quote
Old 09-19-2010, 09:03 PM   #700
RC-ProSpeed's Avatar
can someone tell what's and average weight of the car when is ready to race (chassis, battery, tires, electronics, etc...)
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 09-20-2010, 07:10 AM   #701
scootr117's Avatar
I'm thinking of getting one of these for the Indoor Champs in Nov. I was wondering what part suppliers are the best to find hop ups and likely to have them in stock.
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 09-20-2010, 05:20 PM   #702
lightfoot's Avatar
You can get them to fit , but it's very tight... The fronts aren't too bad, but the rears concave in significantly ...If you want to run F10 rubber on a Tamiya chassis, you need to get RIDE 104 wheels... You can get them through RC Mart... These wheels will fit the F104 but will not fit the HPI F10... not sure what your trying to achieve
Love and Peace...
Old 09-20-2010, 06:43 PM   #703
Airflow's Avatar
Its just that Tamiya's soft compound rear tyres are not that sticky and wears fast. Thats why I want to use F10 rear tyres. Its ok if its tight fit, better. How bout the diameter of the tyres? Is it the same as the F104's?
Old 09-20-2010, 07:06 PM   #704
tha Beast's Avatar
Here's a pic;
im confused as to how this works i thought that the bottom A-arms were solid
REFLEXRACING
MIKES HOBBY SHOP PORTER TX
Old 09-20-2010, 07:57 PM   #705
dag32's Avatar
Trader Rating: 109 (100%+)
If anyone is interested in a HPI Formula ten with Exotek chassis please check it out here. Sorry for the shameless plug
★ David Garcia ★
dag32 is offline   Reply With Quote
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
You Know You're A Rc Maniac When.... Hulk Nitro On-Road 25 02-09-2010 11:23 AM
F1 Racing TimPotter Electric On-Road 501 05-29-2009 11:18 PM
GT Body Thread BlackKat Electric On-Road 11 03-08-2005 03:56 AM
