Old 08-09-2010, 04:29 PM   #661
Exclamation
I was wondering would you guys recommend this car for a first time on roader. i have a slash 4x4 and a slash 2wd before that,so i am not a total newb to rc. Or would you recommend to get a sedan type car first then once my skills are better then get the HPI F10? What would you recommend? I was thinking about the kyosho tf-5s. Thank You D
Daholla77 is offline   Reply With Quote
Old 08-09-2010, 07:27 PM   #662
Originally Posted by CypressMidWest View Post
One note of interest, I am VERY EXCITED to announce that Alpha RC F1 has signed on to sponsor the F1 exhibition class at the Champs this year!!!
Any commercially available F1 Chassis: Alpha, CRC, Tamiya, 3Racing, Cross, Kyosho, HPI, TRG, etc. is eligible. It will be a 210mm max width, foam tire, 2-cell Lipo, Handout silver can class. Looking at the F1 threads here on RCTech, it should be KILLER!!! Can't wait!!
I have never seen any Alph nor know where to get one. How about a photo?
PIRONI is offline   Reply With Quote
Old 08-13-2010, 09:09 PM   #663
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Anyone know ballpark what the stock fromt spring is for thickness??
Matt Reinders
8ight E 3.0
Elite Performance
GMS_Racing is offline   Reply With Quote
Old 08-14-2010, 07:29 AM   #664
abailey21's Avatar
Trader Rating: 36 (100%+)
What have some of you guys done to remedy the chatter in the front end through the corners? I tried heavier springs to no avail, using S compound tires on carpet
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-14-2010, 10:59 AM   #665
oldrcr's Avatar
Trader Rating: 44 (100%+)
Default HPI F10 parts in US?
Hi,
just wondering the best place to order parts from for the Formula 10?
I am after a set of the upper front suspension arms.
oldrcr is offline   Reply With Quote
Old 08-14-2010, 01:37 PM   #666
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi Adam,
I think most of the problem stems from the metal swivel cup in the lower front arm- they pinch the shaft then suddenly release under normal driving. Delrin pivot cups are sorely needed.
For now I coat them with silicone (clean and reapply every week) and have installed Speedmerchant damper tubes with a custom rocker mount on the arm. The tubes need to be shortened a bit. Cool thing is it seems like only the HPI can run this mod and I've noticed it really helps out the bounciness the car had before...
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-14-2010, 01:44 PM   #667
MikeR's Avatar
I'm not sure but it compares to the Tamiya medium spring. I've tried some of the heavier Tamiya springs but I always end up going back to the stock spring. The heavy springs tend to cause front end push and erratic rear traction because of the added bounciness at the front end. That's with foam tires though.
Old 08-14-2010, 02:38 PM   #668
Hi MikeR,
what kind of steering knuckeles do you use? Are these the HPI PArts?
And the rear wheels look like Tamiya-Style? IF yes, how did you fix them?
Thanks a lot for answering
Kind regards,
Kabus
kabus is offline   Reply With Quote
Old 08-15-2010, 02:53 PM   #669
MikeR's Avatar
Originally Posted by kabus View Post
Hi MikeR,
Kind regards,
Kabus
Hi,
Yes, HPI knuckles. They allow the use of F103 rims. HPI also has rear axle adapters for F103 rear rims. These all make the F10 much wider, much like the F103. Not realistic looking but more for top level handling on carpet etc.
Old 08-15-2010, 06:39 PM   #670
MaxSp97's Avatar
Hiro,
YGPM
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 08-15-2010, 06:43 PM   #671
MaxSp97's Avatar
Mike,
Do you have the part number of the adapters for F103 rear rims?
I only saw the Ball Diff Set for Foam Wheels Item Number HPI-102917.
Thanks,
Calvin. L
JOY IS IMPATIENT...
Old 08-16-2010, 10:10 AM   #672
MikeR's Avatar
Originally Posted by MaxSp97 View Post
Mike,
Thanks,
The plan was to post part numbers from the header cards I was saving but my 2yo got hold of them and now I can't find em. The separate parts were left rear hub, right rear hub and new alloy shaft. If you have a ball diff already then it will fit these. I had to get these direct from HPI.
Old 08-17-2010, 10:27 AM   #673
MikeR's Avatar
Found em!
103020 BALL DIFF HUB- FOAM
103021 LEFT CLAMP- FOAM
103022 ALOY AXLE- FOAM
Old 08-17-2010, 06:59 PM   #674
MaxSp97's Avatar
Found em!
Thanks Mike!
Calvin. L
JOY IS IMPATIENT...
Old 08-18-2010, 03:00 PM   #675
Hi,
has anyone of you tried to use a 48 DP spur gear, when using the ball diff?
Is there a special spur gear required?
Kind regards,
kabus
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
You Know You're A Rc Maniac When.... Hulk Nitro On-Road 25 02-09-2010 11:23 AM
F1 Racing TimPotter Electric On-Road 501 05-29-2009 11:18 PM
GT Body Thread BlackKat Electric On-Road 11 03-08-2005 03:56 AM
