Old 05-18-2010, 04:13 PM   #571
robk's Avatar
Trader Rating: 22 (100%+)
The mini lipo holder is sweet!!
Old 05-20-2010, 01:51 PM   #572
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Blueman Austria View Post
Nice! Think i will get one !
A few questions i want to get answered:
Is the holder also suitable for the 4cell Sub-C type batterys?
Does 1cell 12 scale Lipos also fit?
How much clearance is there between the upper deck and the lower deck?
How much are the shipping costs to Austria?
Greetz Rainer
Hi! Works best with standard 7.4v lipos or the mini lipos listed. The sub c and 1cell packs are underpowered.
Top plate height is the same as the current height.
Shipping to Austria is about $15USD
Originally Posted by Team Lotus View Post
MikeR, I went to your website and tried to print the page about your new FX10 conversion, and it does'nt allow all the images to print. Do you have some sort of block on the images?
Hi, No locked images. Not sure why. You may need to try a different browser?
Thanks- wave of the future
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-20-2010, 03:06 PM   #573
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
Default HPI Formula ten
Hi I got mine two days ago and I've been trying to make this car to handle a little better but it seems like I'm not making any improvement with the handling on any adjustments that I made.
I will be running on a medium traction bumpy track here in San Diego other than bridgestone tires aluminum shocks what else do I need to do to make this car handle. Next question is if I'm running Tamiya silver can what size pinion do I need to use on a small to medium size track I'm running 3300 mah stick pack 6cell. Thanks in advance..
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 05-20-2010, 05:26 PM   #574
Originally Posted by MikeR View Post
That looks AWESOME Mike!! Great job!
Hi-LowBlow is offline   Reply With Quote
Old 05-20-2010, 08:26 PM   #575
BadSign's Avatar
If you're still running the stock tires, that's your problem. I think most people switch to the S-Grip.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is online now   Reply With Quote
Old 05-26-2010, 02:05 PM   #576
F1fletch's Avatar
Default Where is the best place to Buy the HPI base kit?
Best price shipped?
Yokomo BD8/YR-10F
F1fletch is offline   Reply With Quote
Old 05-26-2010, 02:09 PM   #577
F1fletch's Avatar
How does the car handle with mini-lipos and a 21.5, that looks like the setup
Yokomo BD8/YR-10F
Old 05-27-2010, 01:35 PM   #578
MikeR's Avatar
Thanks Hiro! Good luck at Reedy.
Old 06-01-2010, 07:55 AM   #579
Trader Rating: 30 (100%+)
Couple of questions for you all,
A co-worker and I are each building an F1. He is starting out stock with the chassis and Tires but used a tekin RS ESC and a Novak 10.5 Brushless motor with stock gearing. He quickly found out it was way too much motor for it and blew the tires.
Mine is still work in progress. My Exotek chassis should be in today along with Acer bearings, I will be using a Tekin RS and looking for some suggestions for which turn motor you guys would recommend.
Also, for both of us, if we wanted to use Foam tires, what would we need in order to use them ? Are there wheels that use the stock hexes ?
darinm is offline   Reply With Quote
Old 06-01-2010, 08:02 AM   #580
BadSign's Avatar
a 21.5 or 25.5 on the rubber tires, and only the Soft Option tires at that
TC Foams will fit the stock hexes, they just look weird.
Old 06-01-2010, 09:11 AM   #581
Thanks !... so I'll get a 21.5 motor to start with.
I have the soft rubber option tires so that should get me started.
On the foams, what is different between the Tamiya F1 foam wheels and the HPI ? I'd like to find foams that would be similar in size to the stock rubber which the Tamiya's seem to be, but not sure if they would fit the stock hex of the HPI.
Old 06-01-2010, 04:06 PM   #582
robk's Avatar
If you are industrious, you could probably grind off the ribs from a set of HPI rubber wheels and mount F1 foam on the now smooth wheels.
Old 06-01-2010, 07:45 PM   #583
Now why didn't I think of that ? Sometimes Genius is simplicity !
Thanks !
Old 06-02-2010, 12:00 AM   #584
HeliYogi's Avatar
Trader Rating: 17 (100%+)
Default F1 & 24 Minutes Le Mans at TQ Sat 5/6/2010
Originally Posted by spring71 View Post
From this weekend, we will have Sunday Club Race.
We have UF1 Series on June 5th, Saturday.
11:00 doors open
1:30 sign ups end
2:00 first 10 minute qualifier (no more than 10 drivers per qual)
2:20 second qualifier
3:00 first 8 minute round (B group)
3:20 second 8 minute round (A group)
3:45 third 8 minute round (B group)
4:05 fourth 8 minute round (A group)
4:30 fifth 8 minute round (B group)
4:50 sixth 8 minute round (A group)
Cool! and we can run a Le Mans at the end of F1 so bring your cars!
I installed 21.5 in the "C" group hoping the battery will get me to the finish line.
This will be the our 2nd Le Mans run, bring your cars
Cheers!
Marcos
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 06-02-2010, 12:25 AM   #585
MikeR's Avatar
Thanks !
Rob is spot on. Here is my shaved F10 wheels mounted to F103 foams. Trued em a little after CA gluing the bead.
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
You Know You're A Rc Maniac When.... Hulk Nitro On-Road 25 02-09-2010 11:23 AM
F1 Racing TimPotter Electric On-Road 501 05-29-2009 11:18 PM
GT Body Thread BlackKat Electric On-Road 11 03-08-2005 03:56 AM
