Old 02-25-2010, 03:20 PM   #481
IndyRC_Racer's Avatar
I just picked up a set of the HPI F10 "M" compound tires. These seem to have less grip (out of the package) than the stock tires. Can someone familar with all 3 types of HPI F10 tires comment on the level of grip on each. It looks like the HPI F10 "S" compound is the softest tires, but where do the other 2 compounds compare?
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 02-26-2010, 09:51 AM   #482
Coldn's Avatar
Send a message via MSN to Coldn
Originally Posted by Team Lotus View Post
Hi everyone! Well I'm sorry to report that so far, HPI has not responded to my email to them concerning them coming out with a graphite chassis or a full-on "pro" version of the Formula Ten. I sent the email back on the 19th, almost a week ago now. I will try sending another email to them about this hopefully today sometime. I will post here if and when I hear back from HPI.
ohh its to bad.. but I will keep wait for this resport. tks Team Lotus
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 02-27-2010, 09:10 AM   #483
Just ran my HPI F10 last night on carpet. Was running against 3 other cars all using stock parts, silver can motors and Tamiya F201 "A" compound rubber tires. The racing was very close and had a lot of fun. We are waiting on the shop to get the HPI "S" compound tires so we can see how they compare.
Old 02-27-2010, 09:11 AM   #484
Exclamation
Well, last night I sent HPI another email requesting any info on the possibility of a graphite chassis for the Formula Ten as well as a "pro" version of the car that can compete with the Tamiya F104 Pro and the 3Racing F109.
I'm not giving up till I get an answer from them!
Team Lotus is offline   Reply With Quote
Old 02-27-2010, 10:37 AM   #485
timmig's Avatar
Trader Rating: 25 (100%+)
I've got the HPI S and M compound tires and BOTH are a LOT grippier than the kit tires I have!! The KIT tires are HARD and smooth and DON'T grip at all. The soft tires I put on the rear---and I'm trying Mediums on the front--haven't races it yet at Westcoast---but may get some practice there next Tuesday. I'll probably pick up some S fronts also just in case I need more steering.
FWIW
Tim
timmig is offline   Reply With Quote
Old 02-27-2010, 12:40 PM   #486
Micro-E's Avatar
Hey, Tim
Let me know how the M fronts work. I am interested in your view on it as I put on the S fronts and I still think steering is a bit lacking.
- Erik
Micro-E is offline   Reply With Quote
Old 02-28-2010, 05:03 AM   #487
Trader Rating: 52 (100%+)
the M's are mediums...so there not going to be more steering than the S's, which are soft compound.I have the same opinion of the car as you do micro-e, it doesn't "turn in" hard enough for me, which is probably a caster issue, ..which, on this car isn't adjustable.what made mine slightly better, was putting the front king pin spacers on the bottom, lowering the chassis, and .016 associated springs on the king pins, with S compound tires in the front. also added a half ounce of weight as far forward as I could on the top deck.
we're only allowed to run odorless traction compound at our track, but what i do is soak the full width of my tires with black can paragon(wintergreen based) at home and store them in a plastic bag during the week. at the track, i treat the full width of all 4 tires with red sap traction compound.this process has produced the best results for steering and rear traction so far. the surface i'm running on is well seasoned indoor/outdoor carpet, which makes traction very similar to a medium grip asphalt surface, it constantly changes with temperature and humidity.
rcracer1958 is offline   Reply With Quote
Old 02-28-2010, 06:38 AM   #488
pejota's Avatar
To adjust caster...
Has anyone tried adding/substracting spacers where the upper arms mount to the uprights on the front part of the chassis? Assembly step #9 on page 15.
I can visually see that this changes the angle the upper arms swing back, but has it produced any noticeable effects?
pejota is offline   Reply With Quote
Old 03-01-2010, 11:25 AM   #489
I practiced this weekend on a ozite carpet track with good traction. Lowering the ride height on the car noticeably improved handling. Car still wanted to lift the inside front in sharp corners (using stock front springs). I was using an old set of the Tamiya F201 "A" tires and they seemed to work well once I brought them back to life with some black can Paragon. I might try some old F201 "B" tires and see how they do with a little tire prep.
- Do the stiffer Associated front springs prevent the inside front tire from lifting?
- What dampening grease have people been using on the stock friction shock and friction discs?
Old 03-01-2010, 06:07 PM   #490
indy racer...have you checked the spacing on your front wheels ?..i noticed that spacing mine out 1.5mm on each side helped with the lifting problem...also increased turn in and front traction. i run associated .020 springs in the front of my F109 on asphalt...these springs might also help on the HPI car.
Old 03-01-2010, 09:14 PM   #491
timmig's Avatar
That's interesting---I'll let you all know after tomorrow night---I'm running in high bite asphalt--the kit tires were SOO bad I was afraid to put S on the front. Could have been a mistake---but I'll see!!
FWIW
Tim
Old 03-03-2010, 02:20 PM   #492
Hi guys, Im a noob to these F10s, Ive got one on the way and looking to do just some ashphalt runs ( No organized racing in area ).
Ive been reading this forum and noticed the mention of "Silver Can" for the motor. Can someone enlighten me on what is the Silver Can motor?
Also I have a Traxxas XL5 and the Traxxas Titan motor fornthis F10, am I way off on trying to use this set up, or will it work to get me going?
I do have the VXL system but from what Im reading its too much power for this vehicle, am I right?
Thanks for all responses.
2Revos 3.3/ 4Tec
Rustler VXL / HPI Flux
F1Pro CC4600 / TT01 CC5700
2XRevo is offline   Reply With Quote
Old 03-03-2010, 04:08 PM   #493
Exclamation
Well today HPI sent me an email concerning my questions about a graphite chassis for the Formula Ten and they said they have no plans currently but are continuing to add more option/hop-up parts. What, I have no idea!
They did not answer my question concerning a full "pro" version of the car so I don't know where that's going either.
Basically they are being very vauge about the Formula Ten
My suggestion is for as many as possible to email HPI and request a graphite chassis and a "pro" version car; that's the only way this is ever going to happen!
Old 03-03-2010, 04:16 PM   #494
MikeR's Avatar
Trader Rating: 15 (100%+)
You may need to tighten down the 2 t-plate o-rings. This is where most of the chassis lift and roll is happening.
I'm using CRC thick damper lube and white associated damper pads (ream the hole open slightly to fit the F10 damper tube). These don't hang up as badly as the stock pads.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 03-03-2010, 06:03 PM   #495
pejota's Avatar
http://www3.towerhobbies.com/cgi-bin...FVSEARCH=53689
Tamiya Silver Can, box stock motor for most of their kits. Dirt cheap and used for many spec classes.
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-25-2015 12:28 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 08:57 PM
How many RC's do you own???? Telengard Electric On-Road 127 02-22-2011 01:52 PM
You Know You're A Rc Maniac When.... Hulk Nitro On-Road 25 02-09-2010 11:23 AM
F1 Racing TimPotter Electric On-Road 501 05-29-2009 11:18 PM
GT Body Thread BlackKat Electric On-Road 11 03-08-2005 03:56 AM
