Old 04-16-2009, 10:09 AM   #1
Default Tamiya Beetle interferance problems...
I've started having some problems with my Tamiya Beetle...
I've lost a lot of range and when it gets more than 10-15 foot away it starts doing it's own thing, i don't even need to be touching the transmitter and it'll shoot forwards randomly and keep going to a while. if i watch the car the wheels and car twitch like it has interferance but i've recharged all batteries and it persists.
has anyone had a similar problem? is it a faulty reciever that's what i'm guessing?
bertiebeetle is offline   Reply With Quote
Old 04-16-2009, 10:48 AM   #2
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
CHeck to make sure your antenna isn't touching anything conductive on the car chassis.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 04-16-2009, 12:58 PM   #3
Hyde's Avatar
I'm geusing its a Tamiya M04L you have.
1. Ill get the reciever away from the motor wires.
2. Make sure your intenna isn't cut or frayed.
3. Make sure the intenna is coming out the body using a intenna tube.
4. Try to put TWO pieces of double sided tape between the esc and reciever.
5. Or it could be diods or capaciters on the motor.
6. Make sure you recharge or put fresh batterys in the transmitter.
I've had bad glitching it turned out to be the reciever.
Goodluck
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 04-16-2009, 01:58 PM   #4
also on my reserve set of trnsmitter/reciever set i need to put the reviever in with the crystal facing away from the motor/ speedo
on my Spektrum set there is no problems
sidecarphil1 is offline   Reply With Quote
Old 04-16-2009, 03:53 PM   #5
Thanks guys I appretiate it, I shall try some of your advice tomorrow and let you know how i get on...
Old 04-27-2009, 12:30 PM   #6
Fitted new reciever and it seems to be working perfect now
Thanks for the help!!
