Old 04-19-2011, 12:31 AM   #241
speed-e's Avatar
Trader Rating: 28 (100%+)
Default LCG V10 for sale $150
http://www.rctech.net/forum/r-c-item...ml#post8985071
Mugen Seiki
MIP
Contrast Neo 2.5 HR, Neo X
V-Speed Engines
RadioPost
speed-e is offline   Reply With Quote
Old 05-24-2011, 08:57 AM   #242
Conrad's Avatar
I emailed tigermoth last week after taking pchroma24's car off his hands but haven't had a reply yet, are they on holiday?
Does anyone have a good base setting for low-med bite carpet with foams and rubber tires?
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 05-24-2011, 08:14 PM   #243
ShadowAu's Avatar
They can be a little slow depending on what your email was about but they usually answer,..
try the standard kit setup... after all the car as developed initially for carpet racing
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 05-25-2011, 07:58 AM   #244
Conrad's Avatar
Cheers Shadow, we don't have the grip required at our club for the kit setup. Is the spring/oil combination comparable to regular upright TC's?
I'm right assuming the set screw in each ballend/wishbone should adjust the ballend position when adjusted? The ballends don't move on my car, just the setscrew moves between the two parts, to adjust the length you have to unscrew the ballend and turn it by hand.
Old 05-26-2011, 04:15 AM   #245
ShadowAu's Avatar
The lay-down set-up is firmer than using the same combo on a regular TC... I never used anything harder than Tamiya Blue springs on mine... and usually use yellow and red... if grip is really THAT low soften the car up and look at gripper tires... I recently used mine for the first time on carpet (on foams) and if I was running there regularly I'd probably go for a hardness at least 5 lower than what most were running.
The setscrew is not like a turn buckle on a normal TC... its only threaded in one direction whereas turnbuckles are threaded in both directions... the only way to adjust settings is how you described... it seems a little cumbersome at first but it means the setup is VERY stable and doesn't need a lot of checking/re-setting over the course of a race day... its also very close to 0.5deg for every half turn
Old 05-26-2011, 07:36 AM   #246
Conrad's Avatar
Thanks for the info Shadow, much appreciated. If you have just run the car on carpet with foams I assume you will have a base setting for tarmac with rubber tires, could you share it?
Old 07-09-2011, 10:37 AM   #247
Hello,
the rear of my tigermoth is a little bit loose,has no grip, how can i fix it, is it possible to use anti roll bar with this car?Which and how?
Are the plastic better?, i mean last weekenk i have a crash at slow speed and the front bumper broke up i think it is too stiff and on every crash i had the front bumper brokes.Any solution for this 2 things?
Thank you!
PS: i have the lay down suspension.
Mankalas is offline   Reply With Quote
Old 07-10-2011, 12:32 AM   #248
ShadowAu's Avatar
Originally Posted by Mankalas View Post
Hello,
Thank you!
Never seen anyone put sway bars on them... and practically there is no way of attaching them...
try softening the rear... also check all your settings and ball-ends... one thing a Tigermoth is not short of is grip
as for the bumper the only solutions are - 1) buy heaps of original ones as the plastic they are made of is rubbish, or (2) make your own bumper out of something else
Old 07-10-2011, 08:14 AM   #249
All right, i will try the box settings again.Do you use the original bumper?or you´ve made your own?maybe we can use a bumper of another brand?
In another post you´ve said that you use tamiya blue springs how many pounds have these?
Thank you!
Old 07-10-2011, 02:50 PM   #250
I have sent an email to Chris and this is his answer:
My first question is what does the material look like? Is it an opaque dark grey or a slightly transparent smoky black. The new bumpers are much better and are molded in a material that you can see light through if you hold it up to the light. This will tell you if the parts you have are the old or new generation
Mine are dark opaque.
So,the have improved the bumpers.
I am going to order a couple and lets see...
Old 07-10-2011, 10:24 PM   #251
ShadowAu's Avatar
Thank you!
I use the orginal ones but I bought a whole heap when I started breaking them... nothing else fits that I've seen as the lay down suspension mounts onto the bumper
As for the springs I have no idea of the top of my head... but a quick search online should provide the answer
I didn't know they have made new bumpers from new plastic... but if its the same as the new pulleys then I am not impressed...
Old 07-10-2011, 10:27 PM   #252
ShadowAu's Avatar
Thank you!
Also try some rear toe-in... I use a 1mm shim
Old 07-14-2011, 10:46 AM   #253
Default LCG V10. Want to buy.
Hello. Have somebody want to sale LCG V10 lay down shock? I want to buy.
And you have paypal . Ship to Thailand (close to malaysia).
Thank you.
thor.caster is offline   Reply With Quote
Old 10-21-2011, 04:39 PM   #254
SNIPR's Avatar
What ever happened with this car? Anyone still using it?
thevinylgarage.com - facebook.com/TheVinylGarage - facebook.com/THETrack806
Not Sponsored by:
Viper | Tekin | Trinity | Serpent | Durango | Gravity RC | Pro-Line | Radiopost
SNIPR is offline   Reply With Quote
Old 10-21-2011, 04:43 PM   #255
Discontinued
Parts support is still there from them but yeah ....
Its awesome looking but no more -_-
If it's Broke Fix it, If it's not MOD it !!!
CillieAcc0rd5o4 is offline   Reply With Quote
Is the AE TC5R made in china or USA? s13evo Electric On-Road 34 04-24-2009 06:57 AM
NEW TC design....have a look at this! wingman2 Electric On-Road 15 04-16-2009 10:18 AM
