Old 12-17-2003, 02:27 PM   #121
Default Re: Re: chris who?
Originally posted by pucho
-Roly from MIA?
-what's up Chris this is Alex's friend (the one that can't drive )
whats up .... later
Chris Tosolini is offline   Reply With Quote
Old 12-17-2003, 03:16 PM   #122
chris have you got a set-up indoor on rubber tyres
i am having abit of trouble setting it up, i cant seem to keep the back end around it keeps stepping out in corners
any help would would be apreciated
cheers Scott
Scott Taylor is offline   Reply With Quote
Old 12-19-2003, 01:29 PM   #123
cheers Scott
move the rear arm forward and use the 3 block and try the rear link in on the shock tower and try to move the ball on the hub in one hole
Old 12-22-2003, 03:22 PM   #124
Hi Chris,
I have one of the Yokomo dual cahrgers. I have been have problems with get an "E" error when I start charging. I am not sure what is causing this. I don't know if I have some thing set wrong or what. It does it with both 4 and 6 cell packs, but only at the very beginning. I have been charging at 5 amps and setting the milliamp setting at 3900, the voltage setting at 9.9v for 4 cell and 13.0v for 6 cell. Are these setting close or am I way off or what.
Thanks, Lee
P.S. Nice toys that you sent Rossi. He blew up the tray already. I had it apart yesterday trying to figure out what blew but no luck.
Founding Member of CORRC
www.OnRoadColorado.com
LeeS is offline   Reply With Quote
Old 12-22-2003, 10:41 PM   #125
Originally posted by LeeS
Hi Chris,
Thanks, Lee
I have not seen this problem but I will go to the office tomarrow and see what I can find out..
Old 12-24-2003, 10:34 AM   #126
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Wanted to say thanks for the great thread Chris and merry Christmas...!
What are you hearing on the Tub car? Also what spool are you running in your SD and how did you make it?
Jeff
Jeff Werner is online now   Reply With Quote
Old 12-24-2003, 12:22 PM   #127
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Chris - YGPM
Old 12-24-2003, 04:37 PM   #128
Jeff
the tub car will be ready soon after christmas and the spool is a oneway epoxied together.
Old 12-25-2003, 02:47 PM   #129
franksbodies's Avatar
sup chris
happy holidays,
frank
franksbodies is offline   Reply With Quote
Old 12-25-2003, 03:43 PM   #130
TLRacing
Todd Hodge's Avatar
Sup Chris...are you planning on any TC club racing at Socal soon?
Merry Christmas!
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 12-28-2003, 09:42 PM   #131
Trader Rating: 4 (83%+)
Hi Chris,
Any advice on how to shim the diff/oneway on the SD? The car is shim according to the instruction. One-way gear keep stripping.
The instruction said only to shim on 1 side of the One-way. Would that be the problem?
Thanks!
slooookomo is offline   Reply With Quote
Old 12-29-2003, 02:27 PM   #132
Originally posted by franksbodies
sup chris
happy holidays,
frank
hey I will see you after the 1st.
Old 12-29-2003, 02:29 PM   #133
[QUOTE]Originally posted by T. Hodge
Merry Christmas!
[/QUOTE
maybe after the 1st, I dont have much fun if all the fast guys are not there.
Old 12-29-2003, 02:34 PM   #134
Originally posted by slooookomo
Hi Chris,
Thanks!
ok look at there gears, were they break. maybe you need too shims on one side to get there gears closer. if ti bindes you need a thick and thin shim. also make sure that the pinion in the diff is not loose going in and out of the diff case. shim it so it wont move in and out.
Old 12-29-2003, 03:25 PM   #135
Curtis Schlaht's Avatar
Send a message via MSN to Curtis Schlaht
What's up Chris?... See you at TrackSide....L8ter
Curtis Schlaht is offline   Reply With Quote
Happy 31st Birthday Chris Tosolini Nova F1 Racer Electric On-Road 3 08-03-2008 03:30 PM
Happy 31st Birthday Chris Tosolini Nova F1 Racer Nitro On-Road 0 08-02-2008 08:38 PM
Chris Tosolini signs with Matrix for the Worlds rcfoolz Nitro On-Road 2 07-27-2008 09:21 PM
Team br00d signs Chris Tosolini...... EddieO Electric On-Road 62 02-12-2007 08:05 AM
Team Corally Signs Chris Tosolini ECHOLogic Electric On-Road 164 08-03-2004 04:39 PM
