Old 12-11-2003, 10:01 PM   #91
Originally posted by kt tracing
Chris,
A couple of questions about your clevland set up. Why did you shorten arms (4mm shims) in front of the car and then equal spacers on the rear arms? Also why use shims on the shocks instead of using more droop? Last what are the stiffness of the gray and brown springs?
thanks
keith
dont know the spring rate, yokomo hard gas spring
Chris Tosolini is offline   Reply With Quote
Old 12-11-2003, 10:03 PM   #92
I dont know. what do you meen more droop. you dont want or need droop on high grip
Old 12-11-2003, 10:04 PM   #93
kt racing's Avatar
Send a message via AIM to kt racing
I never really thought about it to make the dog bones strait. Which dogs are you using? I have tried the aluminum but they don't last. They wear quick?
kt racing is offline   Reply With Quote
Old 12-11-2003, 10:07 PM   #94
kt racing's Avatar
My problem actually is that I have to much grip. I have been having some problems with traction rolling. I'm using orange and yellow springs in rear. I think most of it is the springs are to soft? Any ideals?
Old 12-11-2003, 11:22 PM   #95
Randy Caster's Avatar
Trader Rating: 46 (100%+)
While it's the subject... does anyone know where I can find a complete Yokomo spring list, elec and gas rates.
Old 12-12-2003, 07:18 AM   #96
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Thre was a link somewhere in the massive pages of posts that is on this thread...but I had ran the paper copy off and found that the Front Spring on Chris's Carpet setup is listed at 32lbs and the rear spring is listed at 26lbs. They are current product made by yokomo for the gas car.
Jeff
Jeff Werner is offline   Reply With Quote
Old 12-12-2003, 08:51 AM   #97
Francis M.'s Avatar
kt the brown is the stiffest spring in the yokomo chart and
grey next to it. also the spacer Chris T. used outside the shock
body (upstops) or bumpstop what ever the term is should help
get rid of traction rolling.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 12-12-2003, 03:11 PM   #98
I use the old crome ones from the old car.
Old 12-12-2003, 03:13 PM   #99
the spring you are using is about 15 and 17 lb. you need to use about 25 to 40 lb.
Old 12-12-2003, 03:16 PM   #100
the spring rate is the part # like 17.6.5, that is 17 wire and 6 and one half coil. I dont know lb fore sure
Old 12-12-2003, 03:18 PM   #101
Sweet, good thing to know, thanks Chris.
You gonna run this weekend at T4T, or just hang out?
Old 12-12-2003, 03:24 PM   #102
Francis M.'s Avatar
Are you planning on passing by crystal park sometime this weekend?
Old 12-12-2003, 07:31 PM   #103
Matt Howard's Avatar
Chris- how do you like that G350GT body? I ran it a couple weeks ago and thought it worked pretty good
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-12-2003, 07:35 PM   #104
JimmyMac's Avatar
I'd like to know about the body too. I'm gonna run mine tomorrow on carpet. I'll stick with my setup. That-a-way I can compare it to my Alfa 2.0.
JimmyMac is offline   Reply With Quote
Old 12-13-2003, 10:10 AM   #105
Send a message via AIM to BlackFlagRacing
I just ordered one of those body myself. let me know how it compared to the alfa. I'm going to try the ae springs, purple and copper, for the ntc3. Keith, what shock setup you running? (piston and oil weight)
BlackFlagRacing is offline   Reply With Quote
Happy 31st Birthday Chris Tosolini Nova F1 Racer Electric On-Road 3 08-03-2008 03:30 PM
Happy 31st Birthday Chris Tosolini Nova F1 Racer Nitro On-Road 0 08-02-2008 08:38 PM
Chris Tosolini signs with Matrix for the Worlds rcfoolz Nitro On-Road 2 07-27-2008 09:21 PM
Team br00d signs Chris Tosolini...... EddieO Electric On-Road 62 02-12-2007 08:05 AM
Team Corally Signs Chris Tosolini ECHOLogic Electric On-Road 164 08-03-2004 04:39 PM
