Old 01-21-2004, 08:05 PM   #211
Send a message via AIM to Adam Hartzell
Chris--What springs did you end up running at the Novak race? Also, my boy John (tall, bald, goffy looking guy who used all your drive cups at outdoor nats) was wondering if your were comming to Carpet Nats. Just Kidding Are you going to be there though?
Adam Hartzell is offline   Reply With Quote
Old 01-21-2004, 08:59 PM   #212
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Originally posted by franksbodies
hey Fontaine, most definitely , theres always a party at Fukuyama, have you seen the new paint scheme i did for them.
Yes sir I did. Looks mighty pretty How do you like the one in my avitar? LOL, a local racer asked my this past sunday if I'm really going to race a pretty body like that. My answer is: Yes, it's already got 25 races under its belt and still looks new
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 01-21-2004, 10:04 PM   #213
Default Parma Alpha
Chris...I noticed you ran the Parma Alpha at the Novak race....any feedback on the body?
Joneser is offline   Reply With Quote
Old 01-21-2004, 11:10 PM   #214
Trader Rating: 21 (100%+)
Chris- Can you give me your settings that you use on your BCS charger? Are you using temp peak or standard?
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 01-22-2004, 05:47 AM   #215
pucho's Avatar
Send a message via AIM to pucho
Please check out www.rpmspeedway.com for pre-bird practice information.
Luis
pucho is offline   Reply With Quote
Old 01-22-2004, 10:57 PM   #216
Default Re: Parma Alpha
it was good, only ran it there and I need more testing but I would go out and get one..
Chris Tosolini is offline   Reply With Quote
Old 01-22-2004, 10:58 PM   #217
Im using peak charge and 4.5 or 5 amps and 4500 limit and peak detec .20
Old 01-22-2004, 11:01 PM   #218
THeGame's Avatar
Send a message via AIM to THeGame
Chris are you going to the snowbirds ?
THeGame is offline   Reply With Quote
Old 01-25-2004, 08:50 AM   #219
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
I just saw some pics of the new tub kit that was out in Japan. Looks really sweet! Have you got your hands on one yet? Bet that car would rock at the Snowbirds....
Will be interesting to see how it compares to the plate cars. Any info would rock about the new car...
Jeff
Jeff Werner is offline   Reply With Quote
Old 01-25-2004, 02:19 PM   #220
ya
Old 01-25-2004, 02:22 PM   #221
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
Yo Chris whats up
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 01-25-2004, 02:24 PM   #222
Chris YGPM
Old 01-25-2004, 07:38 PM   #223
Chris,
check your P.M'S on this forum.
BrianJ is offline   Reply With Quote
Old 01-26-2004, 03:47 PM   #224
Lonestar's Avatar
Default SD Setup help?
Hey Chris,
Paul from switzerland here... I'm looking for some advice on setting up the SD... I'd appreciate if maybe you could help.
I'm running the car on carpet with rubbers, in the 12turn class.
Basically I'd been fighting the car for a while to get more initial turn in. I had always run the rear tower up front, the car was always easy, but kinda slow in the technical sections. I figured out I'd try the stock front shock tower... and then, suddenly, the car has agressive turn-in! cool, I think... The problem is, the initial turn in response is awsome and allows me to position the car very nicely into the turns (tight indoor track), but in the apex the car has a strong tendency to "dive", ie the front tires suddenly bite really hard, and, ultimately, spin-off if I let the gas off a little too much.... It is also unstable in the chicanes, towards the end. In both circonstances, I gotta be *very* careful in carrying speed if I don't want it the become *very* loose...
On power behaviour is just fine, the car has plenty of steering, just like I wanted.
I've tried several things to tame down the car mid-turn... reducing rear droop, reducing front camber intake, increasing rear camber intake... I'd like not to loose the initial turn in response. Can you please help?
Current setup: 35 oil ll and #2 pistons all around, stock springs front, second hole from inside on A-arm, rayspeed yellow rear, outside hole on a-arm, front shock tower, one way, short wheelbase, front droop 5mm (underC-hub), rear droop 6mm, long front camber link bottom lower hole, rear camber link bottom lower hole. Stock ssg chassis, no lower ssg plate.
Thanks much!
Regards,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-26-2004, 08:02 PM   #225
Matt Howard's Avatar
Chris- good luck at the snowbirds, are you going to be running the CGM chassis or your own?
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Happy 31st Birthday Chris Tosolini Nova F1 Racer Electric On-Road 3 08-03-2008 03:30 PM
Happy 31st Birthday Chris Tosolini Nova F1 Racer Nitro On-Road 0 08-02-2008 08:38 PM
Chris Tosolini signs with Matrix for the Worlds rcfoolz Nitro On-Road 2 07-27-2008 09:21 PM
Team br00d signs Chris Tosolini...... EddieO Electric On-Road 62 02-12-2007 08:05 AM
Team Corally Signs Chris Tosolini ECHOLogic Electric On-Road 164 08-03-2004 04:39 PM
