-   -   Battery Solder Cleanup (https://www.rctech.net/forum/electric-road/29002-battery-solder-cleanup.html)
jcrouse 12-08-2003 10:38 AM
I am rebuilding some old battery packs. What is the best way to remove ALL of the solder from the ends of the cells so I can start from scratch. The original builder was pretty sloppy.
Thanks,
John
trf racer 12-08-2003 10:45 AM
Re: Battery Solder Cleanup
Thanks,
John
get some solder braiding.
it ll pull all the solder off
Rob Mincey 12-08-2003 10:54 AM
Just be careful not to leave the iron on the cells for too long. Heat = bad.
Rob
Speedie 12-08-2003 11:03 AM
You can either heat it up quickly and wipe it off before it cools with a damp cloth or grind it off being careful not to go through the case. I use my dremel so I dont have to heat up the battery if I dont have to.
Calvin Ng 12-08-2003 03:43 PM
you can use that solder wick stuff
its made out of copper i beleive
just stick it ontop of it and melt the solder it sucks it up pretty good
might have a lil bit though
MrEs 12-08-2003 04:51 PM
what calvin said, its called solder braid
wagonman72 12-08-2003 08:22 PM
Actually it's called solder wick too and sometimes you can get it at Radio Shack. We used to use it for battery bars!
Calvin Ng 12-08-2003 08:34 PM
ha...... ha..........
:nod: :nod: :nod: :nod:
me right also:lol:
thatdog 12-08-2003 09:15 PM
You can go to these sites and get an idea of how to desolder using solder wick.
http://www.aaroncake.net/electronics/desolder.htm
http://www.fixyourowntv.com/howtosolder.html
http://www.mtechnologies.com/building/atoz.htm
trf racer 12-09-2003 12:49 AM
its actually de soldering braid.
thats the proper name for it.
MrEs 12-09-2003 01:58 AM
thank you... :P
trf man 12-09-2003 02:07 AM
Originally posted by MrEs
thank you... :P
lol.
its ok.:D
dtm 12-09-2003 04:14 AM
Solder braid....too much like hard work. I simply melt the solder with one hand holding the cell and then "flick" the cell towards to the floor....the solder flicks off nicely!:D
popsracer 12-09-2003 08:54 AM
Guys;
Buy a quality Solder "sucker" from a local Electronics store. Fast, easy, does a decent job of removing excess solder quickly AND you can use it more than once. A quality tool that will last you a lifetime.
Randy Caster 12-09-2003 09:39 AM
Originally posted by popsracer
Guys;
I gotta agree, these work to get the brunt of the solder off, then you can use the braided copper to get the rest.
