TC3 Forum
Anyone interested in buying a TC3? BMI chassis and lots of aluminum parts, including threaded shocks and loads of extra parts. Only thing missing is a lower spring cup (#6475) to complete the roller.
$90..PM me.
$90..PM me.
Man my bearings were taunting me saying, " Hurry up and pop me!!" So I had to do it and pop one side of all my bearings on the TC3!!! Couldn't help it. I'll tell you this though. You can see and feel the difference. It's worth it. Just maintain it from race to race and you should be well on your way.
Pull the seals out of the bearings. Clean the bearings with motor clener and let dry. Dip the bearing in "TriFlow" which is a teflon lubricant then let the bearing dry. Reinstall the seals.
The teflon will provide an extremely low drag lubricant that won't attract dirt.
Ford F-100 Body fit?
Does anyone know if any of the old 50's Ford F-100 bodies out there will fit the TC3?
hello,
I want to know if it's possible to make a Spec-R gear differential into a TC3?
If it's possible, whats modifications can I do and what differential I must choose in Spec-R products?
Regards,
Adrien.
Regards,
Adrien.
Reply to the two last posts.
1. No idea on the F100 bodies, I have not seen a post in this thread in years of anyone mounting truck bodies to a tc3
2. I dont even know what a Spec R is... and would you not need 2 as the tc3 uses a diff front and rear?
James
James
Spec R makes gear diffs commonly found in belt driven TC's.
Spec-R also makes gear diffs for some of the Tamiya shaft-drive cars, as well..
http://www.spec-r.com/specrr2/module...=index&cPath=7
Im movin your way too... ill be in Mobile after the 11th!
DaveW, YHPM
Ron
Ron
TC3... Rally parts
I have found the 200mm dog bones and 200mm rear arms, but I can't find the 200mm front arms. Any one have a set of front arms to sell ?????
Thanks,
TJ
Thanks,
TJ
what do i need to do to to make battery tray work with lipos
Can anyone tell me the width between the two steering posts (in mm) please.
By steering posts I mean the part on which the BB and the steering rack slides).
Thanks,
Pizza
Thanks,
Pizza
Help With Gearing
I hate a FT TC3 used roller...current I want to up the top end. Right now my FDR is between 7.50 running 25t pinion /75t spur ...I'm running a 17.5BL Novak SS and need to be in the ballpark of 5.50 FDR
Given the nonadjustable gear meshing on the TC3 what gearing should I use?
Thanks!!
Thanks!!
Re...gearing
I installed a 1/12 scale 66t, 64 pitch spur, The holes in the robinson spur gear line up with the holes in assoc drive shaft. 66/30=2.2X2.5 (gear reduction in diff)=5.5FDR. With this set up everything lines up about the same as the 72 or 75 tooth assoc spur. No cutting or dremeling required. I was able to get down to around 4.2 for VTA with no grief. I'm not sure what you mean unadjustable gear mesh???? Mine is the grahite Tub chassis, maybe the FT is different!!!!
Maybe I'm retarded lol...but once I attach the motor mount and pinion it just drops into the graphite chassis. Then the heat sink just locks it in place...
Where do I find 12th scale spurs?
