TC3 Forum
The shock tower screws will press down on the case just over the bearing race. Its best to drill and tap out the two tower holes on each case that ride over the diff bearing race. This removes most of screw installation stress and bearing fit inconsistencies related to case/tower bolt tightness.
After that you want your diff bearings to ALMOST fall out of the trans case holes when installed and tilted by hand. A large Dremel fine sanding drum used by hand to remove high spots will get the job done right. Minimal binding will give you a cooler running motor, freer driveline, and predictable throttle response.
This has been bugging me since the last time I hit the carpet, when I let off the throttle at the end of the straight to make a right turn, the car just spins out without any brake application. I have no drag brake on it, camber is at -1.5 degrees on all four wheels, could this be a diff issue?
- too much rear droop
- car is tweaked or has wedge (check on a 4 corner scale setup if you have access to one; otherwise check that the preload on your springs is equal
- shock issue (a shock has leaked it's oil out and is transferring weight to the front end too fast when you let off)
- cracked chassis, bent hinge pins, other damage
TC3+parts for sale
I will start by rebuilding the shocks. The car has sat for a few years.
Yes and I also went from nimh brushed to lipo brushless power.
Your balance is likely way off then. lipo is much lighter. measure carefully the front and back of the chassis and mark a spot on dead center, then use two xacto razors to balance the car on these marks. add lead to the light side (the lipo side) until the car balances. this could take a few ounces..
TC3+parts for sale
TC3+parts for sale
Is there a benefit to running the new vcs3 shocks on a tc3? Just curious my shocks are pretty beat up and need to be replaced if I should just go with the newer design?
they might be a bit smoother, but probably nobody has used the new tc6 shocks on a tc3. the tc6 is a metric car so the mount sizes MIGHT be different, and the lengths might be different too??
You are probably better off to use the regular tc3 shocks, unless you want to tinker/try something new/are willing to do a little tweaking if necessary.
TC3+parts for sale
TC3+parts for sale
I got a set of Tamiya Racing Factory shocks ( item # 42102 ) and absolutley love them. They're super smooth! I picked them up on eBay for $50 shipped from Tokyo but for approx $80 you can get them quicker by buying from a US seller. It took under two weeks to get them so it's a matter of how fast you need them. I used green slime on them 3 months ago and they have not leaked at all unlike my original AE Team shocks
tc3 manual
Anyone have a factory team tce manual 4 sale?
tc3
my printer broke down, i just wanted original manual if anyone had 1
