Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 10-12-2009, 02:39 PM
  #1276
Metla's Avatar
Originally Posted by NiMo View Post
Have you not heard of gluing the side walls?
Stops all that chunking nonsense
I haven't, What sort of glue do you use?
Metla is offline
Old 10-12-2009, 03:01 PM
  #1277
Brian Jacobsen----tried to answer your e-mail,but somethings gone wrong cause my e-mail ddid not get delivered.
PM me so I can respond
Granpa is offline
Old 10-12-2009, 03:39 PM
  #1278
Bjake's Avatar
Granpa,
You can send me an email here:
[email protected]
Thanks Brian
Bjake is offline
Old 10-12-2009, 04:12 PM
  #1279
R/C Tech Elite Member
JayL's Avatar
Originally Posted by Bjake View Post
Granpa,
[email protected]
Thanks Brian
looking for some HP, eh?
JayL is offline
Old 10-12-2009, 04:32 PM
  #1280
Bjake's Avatar
Talking
I trying to catch you!!!
Bjake is offline
Old 10-12-2009, 08:30 PM
  #1281
Craig P's Avatar
Those of you that have ordered from D Drive, what is the turn around time for a small order? CA USA addy. Thanks.
Craig P is offline
Old 10-12-2009, 10:15 PM
  #1282
RAL
RAL's Avatar
Trader Rating: 66 (100%+)
3-weeks.
RAL is offline
Old 10-12-2009, 11:08 PM
  #1283
zpmhinojosa's Avatar
Default Rubbs.
So I hear all this hype about these rubber tires, well I have a set for my Pro and took it out on our fresh asphalt track, and it was silly all over. Am I being a douche and not doing something right? I think I'm supposed to rub alcohol on 'em. Help...
zpmhinojosa is offline
Old 10-12-2009, 11:52 PM
  #1284
what rubber tires do you have?
krat is offline
Old 10-13-2009, 05:19 AM
  #1285
Big Daddy Cool's Avatar
Trader Rating: 15 (100%+)
The debate over which is better: rubber or foams, is endless. But in truth, it all depends on the track you're running on. In our prepared indoor asphalt track, foams work best and last really long. In another track which is outdoors and less smooth, rubbers work better and foams disintegrate in 10 minutes. Don't insist on using foams when the best option can be rubber (and vice versa). Just like real F1, certain tires work better/worse on different tracks. Find what works best for your track and you'll be a happy racer.
Big Daddy Cool is offline
Old 10-13-2009, 05:42 AM
  #1286
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
usually about a week and a half, but i just id an order with them over the weekend, and it could be here by Friday
He processes al the online orders on Sunday and ships Monday. So if you plan a bit and get your order in by Friday, then you will probably see it the end of that week.
Im in Michigan so that might add an extra day for me.
BP SHADOW is offline
Old 10-13-2009, 08:58 AM
  #1287
Arthur Burns's Avatar
I definitely did get a shipment the following week (within 6 days to California) from D-Drive when placed on Friday or Saturday. EMS Shipping was very fast.
In contrast, a ground order from Canada took over 2 weeks from another company. The biggest problem there was the time it took them to process the order. D-Drive is very fast on processing as long as you order before Sunday.
Arthur Burns is offline
Old 10-13-2009, 09:00 AM
  #1288
Greg Sharpe's Avatar
If I read this correctly, Tamiya has yet to release the classes (and thus rules) for 2010 TCS races....which leads me to a TCS noob question. Can I legally update a Pro to F60 specs for 2010, if they happen to spec rubber tires?
Obviously the parts will interchange, question is, will that update be legal? I am just not clear on how Tamiya views hybrid cars.
Greg Sharpe is offline
Old 10-13-2009, 09:08 AM
  #1289
BP SHADOW's Avatar
You will have no problem interchanging parts as long as there is no reengineering to do so, as far as the 104 goes, the Pro is just the full option car version vs the entry level F60 kit. Whatever Fred and crew spec for tires is what you will have to run regardless of what kit you start with.
Old 10-13-2009, 09:11 AM
  #1290
BP SHADOW's Avatar
Rubber tires take a few runs to get scrubbed in, and are very squirrely till they do so. Also did you apply any traction compound to them?
That makes a huge difference
You may have to make some changes to your setup to get the rubber tires to work as well.
