Tamiya F104 Pro!
#1141
I have a question:
Does the Kawada spur gear adapter fit the F104?
it's for using 64-pitch gears from other manufacturers
Jimmy
Jimmy
#1143
Cool... thanks for the reply... .04 Tamiya spurs are harder to find than hen's teeth...
I can get 64p gears all day long... and 48p as well
#1145
hello
F104 for use on asphalt must be put grease friction hard or soft??
there is a lot of grip
motor brushless 13.5T - LiPo
thank's
thank's
#1147
the spur adapter fits, but the diff is not nearly as smooth with it...
F103 rear tires fit, fronts fit with alittle spacer, search this thread for username 'junnn' ( not DJ) IIRC
That wouldn't be a legal racing setup though, I know you are local to me
#1148
put a lite film of asc. ball diff grease on the inside of the adaptor and it will be smooth as silk
With no grease, it will feel tight after a few minutes of running as the plastic ring gets hot on the shaft if you run it dry
I have used tamiya aw too but like the asc. stuff better and i already have it out for the diff balls. Carbide diff balls will make the diff noticably smoother too.
#1150
If anyone knows a (reasonably priced) place to order Tamiya 0.4 pinions in SoCal (or mail order in USA), please let me know. I want to buy one of each between 26T-31T. $15 for 2 pinions (plus shipping and handling) via Tamiya USA is pretty steep. They are half that much ordering from Hong Kong or Japan, but I would love to give a local shop my money instead, especially if I can avoid shipping and handling charges... Hint hint...
Is it just me, or is it impossible to find everything you need in 1 place? I have ordered from 3 different overseas shops just to get hop-ups and spare parts for 1 car. One shop will have everything but 1 or 2 items, so you have to split up the order between 2 or 3 shops! That gets EXPENSIVE!
Nice to see Gyro Hobbies in Laguna Hills finally carrying SOME Tamiya F1 parts. I'd like to see a hobby shop near the Tamiya track carry a full line of parts for these babies! Seems to me a good business plan with F1 taking off again. Speedtech RC seems to have a good selection, but not everything I want... Who knows what I might spend if I walked into a shop and they had a full line of F1 stuff!!
#1151
http://www3.towerhobbies.com/cgi-bin...?&I=LXN137&P=7
Hpi spur with the F1 axle adaptor. No need to order from Japan.
#1152
Tell me about it... With 3 Tamiya F1's, I am currently in the process of ordering a bunch of spur gears and pinions. Can't believe I've made it this long with only the stock stuff. The spurs can get damaged pretty easily, and I always seem to feel like I'm running the wrong pinion for my tire size. It's hard to keep up with the rollout on the foam tires as they wear. I see some people are running 30T, when I am running 25T or 27T. Not that it matters with all that spinning I am doing, but....
#1154
Maybe I need to get the HPI spur adapter... That solves that problem at least.
