Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 04-03-2018, 08:28 PM
  #9391
JeffofSpace's Avatar
Originally Posted by mtveten View Post
They can be run in either trailing or inline configuration and are even more durable than the stout plastic knuckles.
Thanks! Have been running with the carbon reinforced (or whatever) knuckles...would the feel be about the same?
JeffofSpace is offline
Old 04-03-2018, 08:45 PM
  #9392
Also, had read they need the rm01 kingpins...is this really necessary?
Old 04-04-2018, 08:17 AM
  #9393
mtveten's Avatar
Trader Rating: 29 (100%+)
They use the same kingpins as the regular knuckles.
mtveten is offline
Old 04-07-2018, 09:11 PM
  #9394
What is the purpose of the droop screws in the front attached to the lower arms? Or are they even droop screws? What does this adjustment do in a pan car?
Old 04-07-2018, 09:24 PM
  #9395
mtveten's Avatar
Steering stops and although you can use them to limit uptravel I prefer to use shims on the kingpins to set droop.
mtveten is offline
Old 04-08-2018, 11:39 AM
  #9396
Great. Huge thanks again
Old 05-01-2018, 06:33 PM
  #9397
I cannot get ride height on the front over 4mm. Is it advisable to run without the rubber o rings below the steering knuckle? That is the only way I think I can get up to 5mm ride height.
Old 05-01-2018, 07:08 PM
  #9398
f1larry's Avatar
Trader Rating: 18 (100%+)
you do not need the o-rings use the set screw to hold in place. I have never seen or used o-rings on my f104’s
f1larry is offline
Old 05-01-2018, 09:09 PM
  #9399
I saw them used on a photo from a few years ago. They act as a kind of up stop cushion...the car gets less unsettled coming out of a bump/chassis stays a bit more settled through transitions.
That’s the theory, anyhow
seems to have worked well.
I did see one issue w my ride height. The kit fronts are taller than tcs/crc fronts. I will try it without he orings if I need to get up higher for one of our more uneven asphalt tracks. Thanks
Old 06-15-2018, 10:53 PM
  #9400
bennytheblade's Avatar
Mines on the way!!!
bennytheblade is offline
Old 06-30-2018, 07:46 PM
  #9401
5th wheel's Avatar
Need some foam tire information. I understand the Tamiya A anB tire foam but can’t find any info on the Tamiya HBR tire. What are they used for hot track asphalt cold track asphalt carpet tire only I can’t find any info on the use of these tires Thanks what is HBR stand for ?
5th wheel is offline
Old 06-30-2018, 07:47 PM
  #9402
5th wheel's Avatar
I run a F104
Old 06-30-2018, 08:40 PM
  #9403
this says “medium”
Tamiya HBR Medium 1/10 Scale Foam Front Tires (Formula 1) (2) - ATD Hobbies
Old 07-01-2018, 10:00 AM
  #9404
Like f1Larry said, I’ve never seen o-rings innthat positition before. I’d start by removing those. I’d also remove (or get a thinner one) the spacer at the droop post/steering block. I personally don’t put a screw there, I run a longer setscrew from the bottom to adjust droop.
JeffofSpace likes this.
viking44 is offline
Old 07-01-2018, 02:50 PM
  #9405
F N CUDA's Avatar
Trader Rating: 34 (100%+)
I run a F104
When we ran the F103 on foams, HBR was used in their tire description
Pretty sure the only Tamiya F104 type foams are A and B, soft and firm.
Pretty sure those are F103 tires.
The good ol days.
F N CUDA is offline
