Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 02-09-2016, 10:55 AM
  #9316
Nice set, but I race Tamiya Cup so I must use Tamiya parts. The reinforced ones seem to be sold out everywhere, I hope they will restock soon.
Cheers,
Hugo
HugoW is offline
Old 02-10-2016, 04:54 PM
  #9317
Redwings's Avatar
[QUOTE=Ph3nyx;14383244]it's the weak point of the F104. You can use the TRF102 renforced part or event better, the exotek adjustable front arm set (#1205) http://www.exotekracing.com/f104-adj...front-arm-set/
Worth every single penny [/QUOTE
They are nice and all with adjustments but your going to run into issues the first time you smack the front end. You will noticed that their just like turnbuckles. The plastic will become weak and eventually strip out. Just my thoughts.
Redwings is offline
Old 02-11-2016, 06:29 AM
  #9318
Ph3nyx's Avatar
i have run it for almost a year on my f104pro and then on my exotek F1R2 , and i only broke the central camber piece , one time. No strip out or bending ...
Ph3nyx is offline
Old 04-26-2016, 04:54 AM
  #9319
Hi,
I just bought a stack of 104 Pro bits to change my F103,7 into a 104 Pro (non V2). Is there a general consensus about running a shorty lipo front or rear position? We run relative long outside tarmac tracks on rubber, here.
Cheers,
Hugo
HugoW is offline
Old 05-03-2016, 06:22 PM
  #9320
idbdoug's Avatar
Trader Rating: 41 (100%+)
Does anyone have a rsector widening kit for sale?
idbdoug
idbdoug is offline
Old 12-08-2016, 01:52 AM
  #9321
Hi guys, still looking for info so bear with me. This may have been gone over already in this thread but to read through 622 pages to find the answer is tough so i hope someone can advise.
I'm looking at F1 cars and assessing any options in my area... There's a kit form F104X1 and F104 pro (V1 version not the V2)..
For racing on asphalt which would be the best choice out of these two and which is the better car?
Can you easily convert the F104 Pro into a V2 via some parts and if so what parts?
Many thanks
hannhann00 is offline
Old 12-08-2016, 12:33 PM
  #9322
scirocco14's Avatar
Either would be fine for asphalt, if I was my choice I'd go with the F104X1.
Neither can be upgraded to a V2, completely different type of car (t-bar vs. Link).
Mark
scirocco14 is offline
Old 12-08-2016, 03:16 PM
  #9323
robk's Avatar
Trader Rating: 22 (100%+)
Many thanks
The real question is what are your trying to do? If you are just racing on asphalt, the 104X1 is the better choice of the 2. It's fiberglass and will make more traction. It also has nicer parts in the kit. You're not going to easily convert it to a V2 link car.
If you want to do a V2 conversion within the rules of Tamiya TCS racing, it honestly is not necessary. If you just want to make a link car to run in regular races, you can get an Exotek conversion for the car. It is really way more up to date of a link car versus a V2.
robk is offline
Old 12-21-2016, 02:41 AM
  #9324
Djchow85's Avatar
Hi f1 people
I'm going to be acquiring a f104w gp soon and need to get a body for it. I understand that 3 racing make a body for the 104. Does the protoform 15 also fit?
Djchow85 is offline
Old 12-21-2016, 02:54 AM
  #9325
Originally Posted by Djchow85
Hi f1 people
Yes, Protoform bodies are fine and a much better choice than the 3 racing one.
Gurneyflap is offline
Old 12-26-2016, 02:51 PM
  #9326
Djchow85's Avatar
Djchow85 is offline
Old 01-05-2017, 04:25 AM
  #9327
Djchow85's Avatar
Djchow85 is offline
Old 01-11-2017, 12:04 PM
  #9328
HeliYogi's Avatar
Trader Rating: 17 (100%+)
Default F-1 NW 2017 Carpet GP Invite
FYI
Originally Posted by HeliYogi
F-1 + Le Mans... Get them ready N' see you then!
HeliYogi is offline
Old 02-06-2017, 01:36 AM
  #9329
Djchow85's Avatar
Is there an alternate top deck for the 104(w gp) to allow an easier removal of the battery or do people just dremel it shorter so 4 of the 6 posts remain
Djchow85 is offline
Old 02-06-2017, 06:41 PM
  #9330
mtveten's Avatar
Trader Rating: 29 (100%+)
There is an optional long upper deck to stiffen the car. I used to run mine with only the middle pair of screws in most of the time.
Mark
mtveten is offline
