Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 12-06-2012, 09:01 PM
  #9016
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
You have to shave the inside plastic so that the electronics side pods just clip onto the post.
Dan is offline
Old 12-06-2012, 09:22 PM
  #9017
The Captain's Avatar
That doesn't seem very secure, any issues with them falling off? I'll give it a shot though.
The Captain is offline
Old 12-07-2012, 08:09 AM
  #9018
nrtv20's Avatar
I ground mine almost to a paper thin amount and have had no troubles at all, others have gone further and I've never seen any problems.
nrtv20 is offline
Old 12-07-2012, 08:22 AM
  #9019
I converted my f104 pro with the lipo conversion, it does away with the top deck and replaces it with a smaller one, and the side pods are a different design.
Now that I'm going f1r, the conversion kit is for sale. I'm also selling the f104 pro top deck, main Chasis plate separately.
Boostinswifty38 is offline
Old 12-07-2012, 06:18 PM
  #9020
mkennedy's Avatar
Trader Rating: 26 (100%+)
i used mine with servo tape and stuck them to the battery and around the post as a holder
mkennedy is offline
Old 12-07-2012, 09:27 PM
  #9021
This was my solution, a piece of aluminum
The aluminum piece is held in with a thin piece of 3M double sided tape. There is a piece of foam behind the battery to keep it all the way forward. Just have to remove 2 of the chassis standoffs and the Rx to get the battery out. The Rx is held on with 3M dual lock, so it is removable. Much more secure than the stock plastic pods IMO.
I'll be swapping out that economy ESC with a sensored one soon enough!
Old 12-07-2012, 09:39 PM
  #9022
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Heya Captain
I would highly suggest using 16g wire
That 12g is going to cause a tweak in your pod
RedBullFiXX is offline
Old 12-07-2012, 10:09 PM
  #9023
Originally Posted by RedBullFiXX
Heya Captain
??? Im new to f1, elaborate?
Old 12-08-2012, 06:05 AM
  #9024
12ga wire is stiffer and heavier than 14 or 16ga wire which may inhibit the rear pod from moving freely. Heavy gauge wire is not needed for 21.5 motors.
AreCee is offline
Old 12-08-2012, 07:46 AM
  #9025
Being that F1 cars are lightweight & rear wheel drive, they will never see high current loads, so the use of heavy gauge wire is unnecessary, especially with stock spec motors
Furthermore, lighter 16g wire allows the pod to articulate with more freedom
This is crucial with a pan car
Old 12-08-2012, 08:23 AM
  #9026
HeliYogi's Avatar
Trader Rating: 17 (100%+)
Yes Sir, second that suggestion...
Plug in the battery, put the body on and feel if the T plate moves freely form side to side and back/forward (no cable or body crunch or rub). No contact with cables and body allowed.
The T plate should hold a flat even position whit the chassis as you lift the car up and look at it holding it leveled.
Cheers.
HeliYogi is offline
Old 12-08-2012, 09:09 AM
  #9027
durtbag's Avatar
16g Novak Noodle wire.
durtbag is offline
Old 12-08-2012, 09:29 AM
  #9028
HeliYogi's Avatar
Default St. servo position
Have you tried a low profile steering servo mounted with the horn up? It makes the steering so much precise and gets rid of the Ackerman effect.
Or just pick up the front part of your servo until the turnbuckles are in a straight line to the uprights. Hold it up and tape it like this to the servo holder.
Just a taught,
Cheers
HeliYogi is offline
Old 12-08-2012, 09:41 AM
  #9029
durtbag's Avatar
Just a taught,
Cheers
Yeah, ran a low pro Savox for a while like that, but it got put in the TC. I drilled a second set of holes in my servo horn so can lower the inner links to change the level of the turnbuckles. on foam the steering is pretty agressive.
durtbag is offline
Old 12-08-2012, 10:23 AM
  #9030
durtbag's Avatar
Lowering the inner links gets the tie rods level
durtbag is offline
