Tamiya F104 Pro!
#8867
ok - i hate doing this, but...
is this the thrust bearing - F103 / F104 1 Piece Ball Thrust Bearing - that every one uses to make the F104 diff's better??
I need to finally look at make my rear diff smoother - will this give a little more adjustment range?? I know mine is kind of sensitive for nut movement
#8868
#8870
it actually replaces the bearing inthe hub and you still use the washers. thats what i was told. i think its the 5x13 bearing
#8873
#8875
they are the same ones as the Pit Shumi 571/572 tires..the soft fronts/hard rears work incredibly - just something about them
they say 'for TCS' because tamiya is offering them as another tire option for TCS racing - the difference between the Pit and Tamiya? tamiya's say 'TCS' on the sidewalls while the Pit are smooth
#8876
#8877
I'm just a f1 newb, I also asked this question a few weeks ago. I was told you also put the washers in the opposite dirrection like this )( just an FYI-
It is part #53136 http://www.tamiyausa.com/product/ite...oduct-id=53136
it is used to replace the 1150 bearing in the diff...and put the disk spring in the opposite direction like this )(
#8878
The Thrust bearing from Tamiya works well, but even better one is this (easier to clean and lubricate, seems to last well in my X1 and PRO also) http://www.avidrc.com/product/13/thr...-bearings.html
I get all my bearings from them, no bad bearings so far.
-Pate
-Pate
#8879
don't worry about what the compound names are
Great! Now to check if it legal for our local tamiya races and get them to test it out then.
#8880
