Tamiya F104 Pro!
#8852
Im trying to find a chassis on rcmart the x1 isnt in stock i was talking to some f1 guys they were saying i can get the standard kit and put the f104 aluminium diff the shaft weight and the x1 upper deck bits and it will be like a x1 will it be the same or will there still be some bits and pieces that are different.
think they still might have some if thats what you are really after
#8853
i have a brand new tamiya f104 v2 for sale in box never opened
http://www.rctech.net/forum/r-c-item...l#post11115888
#8856
Need some advice.
I'm wanting to convert my F104pro chassis so I can run shorty LiPos. I don't want to buy an Exotek chassis conversion btw..
I still run the original stock 2 piece graphite chassis. What I'm trying to do is eliminate the plastic side swivel mounts and center my electronics with a shorty on the chassis.
Is this what I need?
http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
Anything else I need than just this?
Is there anything else for consideration?
Thoughts?
Thanks.
Thoughts?
Thanks.
#8857
Need some advice.
Thoughts?
Thanks.
Thoughts?
Thanks.
I have a F104pro and used the X1 conversion kit , this will eliminate the use of the friction plate and then you get the side damper
I use my F104at ETS and we have to use the shorty lipo and a 21.5 brushless set , works brilliantly and i can drive for 20 mins between charging
#8858
Need some advice.
Thoughts?
Thanks.
Thoughts?
Thanks.
#8860
They're out already. SpeedtechRC and TQRC have them. They also arrived at my LHS last week.
#8861
Does anyone have a carpet set up for F104pro with F103 adjustable front end?
Grip level is Med-High
120-130' straight & tight in field
#8862
Need some advice.
Thoughts?
Thanks.
Thoughts?
Thanks.
This is my F104 Pro with a shorty pack.
#8864
So who won the f1 at the TCS finals today?
#8865
Hey Thanks for the help and info.
