Tamiya F104 Pro!
#8776
http://www.tamiyausa.com/product/ite...oduct-id=84115
any one have one of these that they want to sale me?
#8779
welcome to the dark side Graham
A 104 and 104 pro are basically the same car, but the pro has more upgrades, like carbon chassis, alloy motor mounts etc,
These still use a traditional fiberglass tbar system and use friction plates.
you can get a standard 104 in wide which uses the F103 front suspension.
A 104 WGP is almost the same spec as a 104 pro,
but uses the wide F103 front end and has a few more upgraded parts, it still uses a fiberglass Tbar, but instead of the friction plates uses a side roll damper.
A F104 V2 Pro goes back to the narrow front end and does away with fiberglass tbar and uses side springs and a side roll damper,
The V2 also does not come with an alloy motor mount as standard.
I hope this helps
Beth.
I hope this helps
Beth.
#8780
anyone looking for a f104 pro with 2 bodies and sets of wheels few upgrades etc pm me its really cheep as we have no raceing in my area for f1
#8781
A F104 V2 goes back to the narrow front end and does away with fiberglass tbar and uses side springs and a side roll damper,
The V2 also does not come with an alloy motor mount.
I hope this helps
Beth.
I hope this helps
Beth.
The 104, 104 pro, 104 v.2 and 104 v.2-pro? Does the v2-pro have the aluminum motor mount?
Reading all these Difference threads on the different version has made me more confused
#8782
As I understand it there currently is only 1 version of the V2 and I believe that is the pro version.
#8786
Tamiya F104 Variants
For those looking to buy an F104. Here are the variants. Prices are just estimates.
Source: www.f1rccars.com
#8787
very exact and to the point
#8788
Panda
