Tamiya F104 Pro!
#8732
Which batteries should I use? I thought I read the shorty lipos were good, but the turnigys 4200maf 65C I got don't fit they are slightly too wide to go all the way back. I got some Gen Ace 3500 mah 35C that do fit, but I cant put the front holder thing in so they might wiggle a little. Is the C rating important using a 21.5 motor? Seems like a lower C would give me less punch and maybe make it easier to drive? Almost got everything together, Just want to know what most use for batteries. I have a pretty stock F104 Pro- Thanks
#8734
I'm an RC and F1 newb , but I don't think so . If you look back a page or two I had the same problem, got a f104 used and the pod had 1 f103 aluminum piece. Even using diff ride hieght adjusters I still don't think they will come out even.. Look back a page or so and see what happened to me and what the experts said.
#8736
Has anyone tried out the Ride tires yet on asphat .. type A soft on a f-104W..is that a good tire for parking lot running
#8738
Use your turnigy pack. don't worry if it doesn't go all the way back. same if you use your gens ace pack, just put it as far back as it will go and tape it down to the chassis.
#8739
Moderator
Looks good
#8740
Deja Vu,
I made an incorrect statement in my previous post (it was late). With my X1 and shorty pack I only double side taped the bottom. When I had a pro, I double side taped the top and bottom since I used a full sized pack with no side posts.
I feel flex is a personal 'feel'. I don't prefer a car with a lot of flex. I even run my T3 2012 with all the screws in and tight. In my experience, when a car gets too flexy it starts to 'feel' kind of rubbery during the drive. I do try to add some when I feel I need a little more traction that I can't seem to get with suspension changes. I just use loctite (sp?) and back off some screws.
At my last race, outdoor, medium grip, with Tamiya Rubber tires, I found that I tightened the t-bar center screw and loosened the front two screws that hold the t-bar to the main chassis to find rear grip. <- That will probably sound completely wrong to most, but it worked for me on that day.
#8741
The Intellect 50C 4400mah shorty lipo fits all the way back into the rear holder. There is a 1-1.5mm gap between the battery and upper deck but I placed a bit of thin foam that helps secure it better. You actually don't want it all the way in the back unless it is poor driving conditions. I'm getting quite a bit of push in my X1.
I'm building my V2 with the shorty pack more forward.
#8742
Just picked up a f104 pro black. I have a 6.5 vortex pro motor laying around. Am I crazy to think that I can put it in the F104 and just dial it back. Would I even be able to gear it properly to run in the car? Or should I just pick up a 17.5 to put in it. I wont be racing it just running it at practice days. Don't have a class at my track.
#8743
#8744
Thanks for the quick reply. Its an outdoor asphalt track Medium to high traction depending on if the track has been prepped and sprayed with traction compound. Long 220 Ft. back straight and the rest of the track is fairly open and fast. I usually run 2wd modified buggy this is my first on road car.
Also what gauge wire should I run from the esc to the motor. I currently have 12 gauge on all my offroad cars but from what I have read this is to heavy for the F104 and may tweak the rear end.
#8745
Moderator
Thanks for the suggestion on the rear pod flex plate. Right now, mine seems to do pretty well with rear traction...but if I need a bit more sometime, I'll give your idea a try.
