Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 05-23-2012, 02:23 PM
  #8296
Heyyy,this cant be right!
The spur adapter got loose from spur gear and then the spur gear started to wobble as far as the diff plates allowed it to move. -and pinion grinded the spur a bit...
(Using 86t 64p kinbrough spur and 12 balls)
-is the tamiya spur gear adapter supposed to be glued in the spur? or how it is supposed to stick there, the stock spur bearing cant be used so what am I missing here?
-the car is F104X1 if that matters
And I just installed 21.5 motor, is 86/31 ok to start? (2.77 fdr)
Any thoughts of what gearing is needed to be same speed as silvercans on stock 3.6 fdr?
-Pate
fastvee is offline
Old 05-23-2012, 03:03 PM
  #8297
dfiantii's Avatar
Trader Rating: 18 (100%+)
-Pate
I would like an answer to this as well. I noticed this when I put my diff together and ended up grinding down the spacer and adding a bearing to try and take up some slop. Maybe shims need to be added but I have no idea which ones.
dfiantii is offline
Old 05-23-2012, 03:56 PM
  #8298
robk's Avatar
Trader Rating: 22 (100%+)
-Pate
I have never seen this happen...did you have at least 1 bearing in there?
robk is offline
Old 05-23-2012, 04:09 PM
  #8299
dfiantii's Avatar
robk
for my setup i have the spacer then one bearing inside the diff, then i have the thrust bearing on the outside with the to cone washers and the diff spacer i guess is the last part and no matter how tight i try to get it when I spin the diff you can still see it wobble. I ended up shaving the spacer down thinking the diff rings were not applying enough force to keep it in line. Now I am just thinking that the wring itself might not be straight.
dfiantii is offline
Old 05-23-2012, 06:23 PM
  #8300
Trader Rating: 21 (100%+)
Mine has always had a bit of wobble (slop), but it's never caused the car to eat any spurs. I'm running the same setup; 64p kimbrough with 12 diff balls and one bearing inside the diff. No glue on the adapter, just pressure fit.
Is it possible it was a mesh issue?
silencery is offline
Old 05-23-2012, 06:29 PM
  #8301
mkennedy's Avatar
Trader Rating: 26 (100%+)
The spur will have a small amount of play, side to side. This is due to the gear floating on the diff balls.
mkennedy is offline
Old 05-23-2012, 06:39 PM
  #8302
I had the adapter slip on a spur gear of mine as well. A spacer of some sort should work fine I just haven't gotten around to it due to switching to the FGX.
InspGadgt is offline
Old 05-23-2012, 11:58 PM
  #8303
kneedeeppow's Avatar
i use the kimborough spurs and see this wobble also. i wonder weather the recesses or little 'pockets' that the balls sit in,are slightly to tall and effect contact of the diff ring. i know it would make it difficult to place the balls onto the spur but would a thinner pocketed spur help with diff smoothness?
kneedeeppow is offline
Old 05-24-2012, 01:32 AM
  #8304
Wobble is normal...that is because the diff balls are wider than the spur gear so the spur gear floats on them. If it didn't then the diff rings would be rubbing on the gear and the diff wouldn't work right.
Old 05-24-2012, 08:48 AM
  #8305
Wobble left to right is normal(if looked from back of the car) ,but the adapter slipped out from spur and the spur started to wobble front/back. So that needs sorting,maybe gluing the adapter in the spur.
fastvee is offline
Old 05-24-2012, 10:52 AM
  #8306
MantisWorx's Avatar
Trader Rating: 28 (97%+)
IF any of you are fans of RC F1 you need to make it down to Texas on june 16th!! this is our test race for our upcoming summer series! We have joined forces with UF1 now and expect 30+ entries locally hopefully more if we can get the Austin and Dallas peeps out. Kick ass track and facility, had the nitro TC worlds here two years ago.
http://www.uf1houston.com/index.php?...eries-race-r31
MantisWorx is offline
Old 05-24-2012, 11:16 AM
  #8307
I glued the adapter in place. Tested the X1 for first time. BIG crash. enjoy
+ YouTube Video
The carbon reinforced parts are not that strong...
Thanks to BP SHADOW for the decals.
-Pate
fastvee is offline
Old 05-24-2012, 06:05 PM
  #8308
ioyasm's Avatar
if your running with small diff balls it will burn out the spur gear
ioyasm is offline
Old 05-24-2012, 06:18 PM
  #8309
texastc's Avatar
Dallas posse will be there
texastc is offline
  #8310
robk's Avatar
Originally Posted by dfiantii
robk
Like the other guys said the diff gear will wobble. Basically the spacer is going out of the spur and migrating toward the bearing...weird. Most of the spacer I have are pretty tight on the spur, does your slide in and out easily?
The other alternative is glueing it like these other guys did. Maybe just a couple dots, though, so you can try to re use it.
robk is offline
