Tamiya F104 Pro!
#8283
i found some F103 RD special king pin set (racing developed) with part nr 53119.
I think they are the ones i need.
#8284
greetings to fellow rcf1'ers. i am experience a problem with the steering in my 104. the servo has begin to move off center. i have to adjust the trim constantly left then right to make it straight. so i put a different servo in with a new servo saver and the centering of the servo still moves just like the original one.hmmmmmmmm,its got me a bit stump. i rebuild the kingpin,spacers and they all are free.
any thoughts for me guys?
thanks
thanks
#8286
thanks
thanks
#8288
thanks
thanks
If you are not hitting anything, then ignore this message.
#8289
i have used the futaba s3003 then try two of the lower end savox digital servos
when i try the two savox servos one had a plastic servo horn and the other had a different horn
oh yes,i wish i could stay away from the barriers but it is always going to happen
i did not know there was options for the ball cup. that could be something to try. is there a part number?
thank you for the feedback everyone
#8290
#8291
With the guys running the 104's in w / wgp configuration what rubber tires are you finding work best on the cars?? The 103 tires or 104?? I have seen a couple of people getting good results with the 104 tires but was not sure how they compare to the 103 tires as there seems to be allot more choice of rubbers with the 104 tires..
#8292
#8294
2 questions
i have a a set of fgx wheels with hpi tires, and a set of ride wheels for fgx with hpi tires, will these fit on the 104 or should i sell them with the fgx roller.
i also was couious if the savox 1251 servo would fit in the 104.
thanks. it seems no matter what i do the f104's are always a lil faster than fgx.
#8295
