Tamiya F104 Pro!
#8071
Any idea which is the softer setup? Just going to install aluminum motor plates on my X1 later on and deciding if I should mess with the T-bar.
Running on asphalt and foams, may switch to rubber in the future.
#8072
Haven't seen any pics yet
#8073
Running my f104x1 with tamiya tires and looking to get more rear traction as the car wants to come around to easy. What can I change to get the rear to stick.
#8074
Theres many adjustments for many different types of oversteer. Changing weight, grippier tires in the back, more downforce, softer T plate, lighter spring, lighter damper grease. It all comes down to what is causing the oversteer.
#8075
just wanted share my experience since i saw another x1 model. My X1 is pretty much default setting by manual. At first, almost impossible to drive due to oversteering. tried to play with camber setting to 2 and made some difference but not enough. The last thing i tried was tamiya #53259 F1 3.5mm Offset Upright F103 / F104.
After this item should be 'must-have' to all the 'x1' owner. the result was unbelivable.
#8076
just wanted to ask experts on f1 setting out there about the issue i've been having from day 1.
1.I tried to rebuild diff several times on my x1 to get that 'smooth' feel. I was never successful. it IS smooth before I lock the nut but as soon as I lock it, it feels bumpy when i turn it by hand. the current setting is 90 degree CCW after full lock. Is there any tip I should remember other than manual? I've been researching this issue since I bought the car and nothing yet.
2. how hard do u guys hit break for tight corner after long straight? I set to fast on my radio for ABS and my car spins every time. Is there any magic for this? My setting is default by manual.
THat's it for now.
Since there's no one around my area running f1 im running at prking lot at night after work alone. Even so I have a blast alll the time. F1 is just freaking cool!!
THat's it for now.
#8077
THat's it for now.
THat's it for now.
2. Very much depends on your esc/motor/radio. Mine is at around 80% travel on the radio. 100% on esc. Just keep reducing your brakes on the radio till it stops spinning
#8078
1. Sand the diff plates with 400-600 grit sandpaper. Are you tightening till it won't tighten any further? If you have you likely damaged the diff balls. You want to tighten till the diff doesn't slip. Then tighten 1/8 of a turn at a time till you feel the car drives how you want.
2.what do you mean by 80% travel / 100% esc?
Btw thank you for the quick response. I appreciate it.
#8079
1. To add... To check when the diff stops slipping you hold each half in your hand and try turn the spur with your thumb. If it moves tighten the diff more and try again.
2. I don't know what adjustments your esc or radio has for brake. Just aim for 70-80% brake force
#8080
do you have any idea if a 104 pro version 1 can be converted to 104 pro version 2?
#8081
Nobody has seen the v2 yet. The only information out is exactly what was posted 1-2 pages back. So nobody knows yet if one can be converted to the other.
#8083
Yes, I think that it'll be too expensive (if possible). They say that diff is modified, motor mount from RM-01 ect. It looks like only front end is (or will be) the same as F104 version I...
#8084
The t bar is definitely softer on the f104w gp than the high traction t bar from the x1. Since I dont need the bottom chassis/t-bar for the f1 ultra I think I may actually use it on the x1 instead. Should yield more traction. It is also 21 grams lighter than the frp bottom+t bar+carbon reinforced bottom plate
By the way since day 1 I was running my x1 with alloy motor plates. I just switched to the carbon reinforced ones and the car seemed to be faster. setup was approximately 20 grams lighter than all the alloy bits.
#8085
THat's it for now.
THat's it for now.
