Tamiya F104 Pro!
#7831
I run the rear end as "loose" as possible. I removed the friction disks altogether, loosened the t-bar screw as much as I could, although I will glue the oring in place cause loosening the screw to much can cause drag on the ground. Also soft rear shock with the spring wound almost all the way out (again depends on how tall your tyres are and ground clearance). Also I run the TRG wing, the Tamiya one os useless and I kept breaking them from the smallest hits. Now I have the problem of plenty of rear grip and not enough front!
But working on that.
Oh and I also run the front higher then the back, tried it the other way around with no success.
#7832
The F104pro kit rear tyres, can you get the exact same tyre but for the F103 rims?
#7833
#7834
#7835
Right... I might have to have a fiddle.
I was having a real issue with the back wanting to spin around in corners, so I changed a few things and went to foam 25's on the back.
The back is nice and glued now going through corners and now just need to sort the front.
In saying that I have just changed to the 3racing F103 front end and still tuning it. Was running 0 camber, wound it in a bit to about 1.5-2 degrees camber which helped.
I also have the castor adjustment as well which I am yet to play around with.
#7836
Use this mod on the T-bar http://www.rctech.net/forum/attachme...-pro-t-bar.jpg.
It will give you more rear bite
regards Roy
regards Roy
#7837
I tried the sponge but found you had to cut it in half for it to work. The full sponge causes the car to arch in the middle
#7839
#7840
Anyone have a starting roll out for a Reedy Sonic 21.5? Track has an 80 to 90 foot straight. I plan to use the stock 93 tooth spur since I actually got the diff pretty smooth with the stock spur.
#7841
With or without a battery fitted??
I never had the car "arch" in the middle with the sponge
With a battery fitted, and it depends on what battery the t-bar will sit equall or a bit higher then the chassisplate.
If it arches up the the spring tension is to high.
If it is opposite you need to preload the spring a bit.
regards Roy
regards Roy
#7842
I just received my f104 3.5mm uprights yesterday.
I looked at them up close with my original ones and cannot
notice a difference at all. Is it very subtle? Anyone know?
Should it be a big difference. Maybe they're already on my car.
#7845
regards Roy
regards Roy
I didn't end up trying it but if the sponge was cut in half it definitely would have worked great.
