Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 01-18-2012, 04:40 AM
  #7426
mattwoodcraft's Avatar
Originally Posted by dfx
How do You guys measure caster when building custom made link setup? Is there any accurate and simple solution?
i measure it now with a camber gauge no wheels and measure the angle of the hub, before a made the conversion i measured what i had and then done the TRG conversion that was posted a few pages back. it has really made a positive difference with the set up i have i use 9 degrees with the way i measure it at the moment
mattwoodcraft is offline
Old 01-18-2012, 05:21 AM
  #7427
dfx
dfx's Avatar
Originally Posted by Pro10noob
I have seen people use there TC setup system with a adaptor for the f1 axle.
Other use a camber gauge when the tires are mounted.
Caster adjustment is another thing.
regards Roy
But TC front caster is adjusted by changing hub carrier (C-hub), isn't it? I need to measure angle of a king pin (from horizontal line) to make the wide link setup as much as possible similar to my narrow F104 setup. With plastic camber plate it should be 0,5 of camber and 3-4 of caster. I'm not sure about caster.
BTW trying to build something like this...
dfx is offline
Old 01-18-2012, 08:36 AM
  #7428
Pro10noob's Avatar
With that setup and you change one of the links it will affect the other settings also.
You can check caster with the camber gauge.
Put the car on a flat surface with the axles in the air without wheels.
Put the camber gauge next to the side of the car and adjust it to the point that it is parrallel to the kingpin.
That is how you read it in degrees
Simple and effective
regards Roy
Pro10noob is offline
Old 01-18-2012, 10:02 AM
  #7429
idbdoug's Avatar
Trader Rating: 41 (100%+)
With a stock f104pro, what is the largest mah lipo that i can use??? Any recommendations!!
idbdoug
idbdoug is offline
Old 01-18-2012, 10:40 AM
  #7430
Odin544's Avatar
Trader Rating: 93 (100%+)
I've got a reedy 628 in mine. 5500 mah.
Odin544 is offline
Old 01-18-2012, 11:07 AM
  #7431
nrtv20's Avatar
idbdoug
All depends on the shape of the Lipo; I am running a more squared off Gens-Ace 5000mah but I have to remove screws to get it in and out of the chassis.
If you dont mind taking out 3 screws then I'm sure up to a 5600mah batter will fit.
nrtv20 is offline
Old 01-18-2012, 01:06 PM
  #7432
dfx
dfx's Avatar
Originally Posted by mattwoodcraft
i measure it now with a camber gauge no wheels and measure the angle of the hub...
I'll give a try. Only thing is that I'm not sure how many degrees my setup sys shows...
IP 5800 T-plug hard case might fit stock setup but I'm not sure about changing battery. Our club member has this battery in car and said no mods needed. BTW post are 26mm so max. height of a pack is 26mm and 47mm case fits in between stock post from left to right (cutting some plastic from trays or sticking electronics to battery needed).
dfx is offline
Old 01-18-2012, 01:14 PM
  #7433
idbdoug's Avatar
Ok, thanks
idbdoug
idbdoug is offline
Old 01-18-2012, 03:07 PM
  #7434
Default Gearing
Hi guys,
Just a quick question, I've been looking around trying to find out but I'm not having much luck..
What pitch is the gearing on the F104W? Is it 48dp or MOD 4 or MOD 6 or something else?
Any help much appreciated,
Thanks,
Joe.
Joe_K is offline
Old 01-18-2012, 03:43 PM
  #7435
texastc's Avatar
idbdoug
Did you get it? Let's see it! Hope you have it out Saturday
texastc is offline
Old 01-19-2012, 12:07 AM
  #7436
a nice video from xtremespeedways @ Heraklion/Crete.
Tamiya f104 x1 shimizu tires 8.5T BL 3.2 Gear Ratio
+ YouTube Video
jlask is offline
Old 01-19-2012, 01:13 AM
  #7437
tudor_47's Avatar
+ YouTube Video
Very nive!
Refreshing to see someone driving with a little more motor in the cars... reading the forums you could easy come to think that it is only 21.5 or 17.5t motors in these cars...
And driving in the wet too!
What type of ESC are you using and is it waterproof?
tudor_47 is offline
Old 01-19-2012, 01:23 AM
  #7438
jake95's Avatar
Trader Rating: 27 (100%+)
hi
i got a standard f104 i wanted to know if the f109 diff will fit in it
thanks
jake
jake95 is offline
Old 01-19-2012, 03:27 AM
  #7439
hey. y is it that every f1 uses foam tyres but touring cars are better with rubber?
mitchie is offline
Old 01-19-2012, 04:13 AM
  #7440
NiMo's Avatar
2wd and 4wd.
TC used to run foam here in early days (late 90's) but then the rules got change to rubber to reduce costs (yeah right).
2wd not so easy to use on rubber (not actually rubber anymore) outdoors and the current rules have not yet said we cant use foam.
Nitro TC runs Foam, but electric TC runs pretend Rubber (Latex I think it is now)
NiMo is offline
