Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 01-11-2012, 03:55 AM
  #7351
rcdave1's Avatar
Trader Rating: 14 (100%+)
Originally Posted by aarcobra View Post
RC DAVE-Get rid of the outer rib, both inside and out side? On the outside, do you just glue the sidewall "flap" on the tire to the similar looking area on the wheel?
Thanks,
Ned
Ned, the outer rib on the front and back of the wheel! If you run the plated wheels make sure you sand the metallic off the area to be glued. I've mounted 2 ways. (1) gluing the flap just like the foam wheel (2) flipping the tire inside out and carefully removing the flap with a pair of body scissors and reversing the tire so the cut part is on the back of the wheel. This is a very clean look like a touring car tire and wheel mounted. Make sure if you are going to cut the flap off leave the flat bead part intact!!!! Very important!
rcdave1 is offline
Old 01-11-2012, 04:10 AM
  #7352
rcdave1's Avatar
Originally Posted by texastc View Post
so looks like we know why they are out of stock
Mmhmm! I finally found some at a Canadian hobby shop, hobbyhobby.com had them in stock and I should have them by saturday for some racing on the rug! One sidenote though the shipping was as much as the wheels! Oh well you play you pay
rcdave1 is offline
Old 01-11-2012, 08:42 AM
  #7353
Great info! Thanks, I'll take a look at my parts and give it a try!
Ned
aarcobra is offline
Old 01-11-2012, 08:47 AM
  #7354
Yeah these guys that stock up on parts!!! I have half a dozen F1's and hardly any spares that matter! (and no place to run 'em-might try HOTSHOTS in GA. Saturday if I can get info on times etc.
That's a good thing tho, most guys will share if you need stuff!
aarcobra is offline
Old 01-11-2012, 02:13 PM
  #7355
hanzo3's Avatar
Trader Rating: 55 (100%+)
The actual nut driver is too large to use. Do they have diff thickness 7mm drivers?
hanzo3 is offline
Old 01-11-2012, 02:16 PM
  #7356
rcsuicide's Avatar
Can somebody tell me if the F104 Pro is less than 190mm wide?
rcsuicide is offline
Old 01-11-2012, 02:27 PM
  #7357
MikeR's Avatar
Trader Rating: 15 (100%+)
Time to take your car to Shaun at TQ and let him sell you a proper fitting nut driver
MikeR is offline
Old 01-11-2012, 02:28 PM
  #7358
Pro10noob's Avatar
Erhmmmmm..it would be more like 180MM wide
regards Roy
Pro10noob is offline
Old 01-11-2012, 04:58 PM
  #7359
Csaari77's Avatar
Trader Rating: 34 (100%+)
Is it still necessary to cut the ears off of the servo if I'm using a low profile layed down?
Csaari77 is offline
Old 01-11-2012, 05:30 PM
  #7360
texastc's Avatar
no
texastc is offline
Old 01-11-2012, 05:31 PM
  #7361
texastc's Avatar
I have to use a socket wrench, my nut driver is too big too.
That sounded so dirty.
texastc is offline
Old 01-11-2012, 06:25 PM
  #7362
robk's Avatar
Trader Rating: 22 (100%+)
In case of emergency, Tamiya 4 way wrench...they come in every kit
robk is offline
Old 01-12-2012, 12:30 PM
  #7363
no
Could you guys provide picture on a setup with a low profile servo without cutting out the ears? Just got a Savox 1251 low profile and honestly would hate having to cut out the ears of the thing.
arix is offline
Old 01-12-2012, 12:49 PM
  #7364
texastc's Avatar
here you go
texastc is offline
Old 01-12-2012, 03:14 PM
  #7365
Csaari77's Avatar
Got my servo mounted. Fit perfect and doesn't seem to hit the servo mounts. Now I just need to route the wires so it doesn't look like spagetti and I'll be done.
Csaari77 is offline
