Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 01-06-2012, 03:35 PM
  #7276
miller tyme's Avatar
Got any Exotec F1r's
miller tyme is offline
Old 01-06-2012, 03:46 PM
  #7277
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
No, but I will shortly, along with the new steering setup as soon as I can get them
BP SHADOW is offline
Old 01-06-2012, 04:02 PM
  #7278
Let me know when you get them please.
Old 01-06-2012, 04:35 PM
  #7279
ChadRacing's Avatar
does anyone know why the pit shimizu tires have to mount on foam wheels? And are they difficult to mount? Can the Ride tires mount to rubber wheels or are they also for foam wheels?
ChadRacing is offline
Old 01-06-2012, 04:44 PM
  #7280
mattwoodcraft's Avatar
go back one page and there are pics on how to do the mounting
mattwoodcraft is offline
Old 01-06-2012, 04:55 PM
  #7281
dg8one's Avatar
anybody have an extra spur gear adaptor i can buy
dg8one is offline
Old 01-06-2012, 05:33 PM
  #7282
texastc's Avatar
Pits are made for the Tamiya foam rims, but they will work on the Ride rims. Easy to mount on either rim. I dont know why
texastc is offline
Old 01-06-2012, 09:19 PM
  #7283
robk's Avatar
Trader Rating: 22 (100%+)
Pits mount on foam rims because they were made for Tamiya foam rims. They don't have the bead that the tires made for the rubber rims do.
robk is offline
Old 01-07-2012, 05:00 AM
  #7284
dfx
dfx's Avatar
Default My F104Pro EVO
Here's picture of my F104Pro "EVO" setup for our indoor carpet season. Tomorrow I'll be racing for the first time with short lipo battery, so I'm not sure about weight balance and steering. Maybe I should raise the back of a car and/or add camber. What do You think?
Configuration: laid down low profile servo (Exotek servo mount), custom made RC tray and posts, X1 upper deck+roll damper, X1 rear shaft counterweight, short lipo (Pro-match racing), Tekin RS and SP 17,5T motor.
dfx is offline
Old 01-07-2012, 05:13 AM
  #7285
looks good i have been thinking of trying these short lipo packs for a while now it gives you a whole lot more room in the car idoes leave the front end a whole lot lighter ?
Old 01-07-2012, 05:14 AM
  #7286
looks good i have been thinking of trying these short lipo packs for a while now it gives you a whole lot more room in the car does it leave the front end a whole lot lighter ?
Old 01-07-2012, 06:22 AM
  #7287
Taylorm's Avatar
......BP..i purchased your decals from TQ to do a Senna car..........what paint are you using to do the wheels gold and the wings red?........thanks.........
Taylorm is offline
Old 01-07-2012, 04:16 PM
  #7288
BP Shadow
got my FRP chassis a while ago went out the other day at the race track to test it out i am very happy with thanks the F1 is more locked in now more than ever before, i had to change my T plate as the rear end was locked in to much
thanks again for your help.
i have a question regard ing bearings supporting the rear axle for some reason i now have a slight issue the LHR bearing always seems to fail on a regular basis, it may have something to do with our first corner maybe after a long straight and into a RH turn but i will do 2 or 3 bearings in a day.
i have no problem at all changing these as they are cheap to do so, nothing is bent does anyone else have this problem ?
Old 01-07-2012, 07:00 PM
  #7289
Csaari77's Avatar
Trader Rating: 35 (100%+)
I have some questions about mounting a laid down low profile servo. What servo saver are you guys using? How many spacers are you typically using to flatten out the steering arms? Are any mods to the mounts necessary to get the servo to fit correctly?
Csaari77 is offline
Old 01-07-2012, 10:01 PM
  #7290
I use the savox 1251low profile servo standard servo saver you will. See longer ball studs . I have 4 mm spacer which gives me 0 bump steer
