Tamiya F104 Pro!
#7246
This is my mod for Rubber Tires
#7248
you need:
-F109-05 Aluminum Center Rolling Damper For F109
-Plastic Parts Part B For F109 (one little parts to this kit, look photo)
-one BALL STUD 4.3X13MM
-HB 67718 Sway Bar Holder TC (one plastic uniball)
-x4 1.5mm shim
-x1 0.75 mm shim
-x1 2mm shim
home made mod
-2.5mm hole on the friction plate,
-3 shim 1.5mm to raise the friction plate
have fun!
good work!
#7249
Hi - can anyone explain me what can i do with the Ride tires H1 in the front to become 3.5 mm ground clearance ?? I've tried everything, but the lowest is everything 4.8 mm ground clearance - if I attach under the steering arm more like 2.5 mm, the kingpin touches me on the wheels. hope someone can help me - thank you
#7251
#7253
..Are most guys running 64P pinions with the stock spurs?......
.............Or do you get a better mesh with Tamiya pinions?
#7256
#7260
I thought that I saw an ad a while back, that said GQ tires now sells F104 foams mounted and loose............
:ti re:
Ok, surfed the net and found the link, but I personally have not ordered from this company.
GQ F104 Foams
Opps, just reread the post. you guys want foam rims.
Dave the 'C' should have them in the box behind the counter.
GQ F104 Foams
