Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 12-23-2011, 01:10 PM
  #7186
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by robk
I have found the same thing. I even went to a graphite chassis on my X1 at the Tamiya nationals to take away steering.
Oh that's right and didn't the Nats winner use a 104Pro- the double deck stiff set up?
MikeR is offline
Old 12-23-2011, 01:13 PM
  #7187
MikeR's Avatar
Originally Posted by JamesHealey
I still can't get my EXO104 as dialed as my F103, I know the setup is there it's like you said the stiffer chassis responds to changes better so my lack of setup knowledge/experience makes setting up the EXO104 harder.
I'm convinced the setup to make the EXO104 drive as well is in there just it's on more of a fine 'point' than the F103.
Totally to do with chassis stiffness too.
Running rubber or foam?
Move as much weight as possible to the rear of the car , 15wt side dampener oil and use super soft side springs (raise up the side springs in fact so that it does not touch the side links). It should stabilize the car greatly.
MikeR is offline
Old 12-23-2011, 01:14 PM
  #7188
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Originally Posted by MikeR
I noticed while prototype testing that a flexible chassis created more steering I was told by someone in Japan that that would happen. I think it is because the front is lighter and narrower then the battery end so unsprung weight at the front naturally creates more responsiveness at that end.
I think Tamiya uses the fiberglass to add a little steering, make the car heavier (more stable) and save on some $$$. Fiberglass is 1/4 the cost of good carbon fiber....
I stand corrected. I was sure that my 103 got much more traction with the short top deck and FRP chassis?
Is the difference more of an F104 thing or did I just have it wrong all along?
Both of my F1s (103 and 104) are short top deck and FRP chassis and feel pretty good.
F N CUDA is offline
Old 12-23-2011, 01:24 PM
  #7189
MikeR's Avatar
Users experience may vary- no correction needed as you are doing quite well I think what's great about F1 is that we are all still learning what does what and so makes for a level and fun playing field
MikeR is offline
Old 12-23-2011, 01:26 PM
  #7190
MikeR's Avatar
RC MAN (Hong Kong)magazine is doing a Exotek F1R build up in the next issue. Check it out!
MikeR is offline
Old 12-23-2011, 02:12 PM
  #7191
Matthijs's Avatar
here is the f140x1 from lee martin, I guess with some f104x1w parts on it ;-)
Matthijs is offline
Old 12-23-2011, 08:50 PM
  #7192
robk's Avatar
Trader Rating: 22 (100%+)
Yes it was a double deck car
robk is offline
Old 12-23-2011, 10:12 PM
  #7193
Would like to know from where he got the carbon top deck! Car looks very good!
arix is offline
Old 12-23-2011, 10:22 PM
  #7194
Csaari77's Avatar
Trader Rating: 35 (100%+)
I think the top deck and lower deck are from the new F104W chassis that is coming. The lower deck has been cut to include an extension under the rotating trays.
Csaari77 is offline
Old 12-24-2011, 10:12 AM
  #7195
MaxSp97's Avatar
Merry Xmas everybody...
MaxSp97 is offline
Old 12-24-2011, 10:41 AM
  #7196
dg8one's Avatar
here is my 104pro w/ exotek chassis
dg8one is offline
Old 12-24-2011, 01:20 PM
  #7197
This is an excellent top deck for F104http://rsector.com
ME-student is offline
Old 12-24-2011, 02:04 PM
  #7198
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Yes it is, and it's available here:
http://f1paintlab.com/zencart/index....jbf7fe61v165f2
Merry Christmas to all who celebrate
BP SHADOW is offline
Old 12-24-2011, 04:34 PM
  #7199
mkennedy's Avatar
Trader Rating: 26 (100%+)
+1!!
mkennedy is offline
Old 12-25-2011, 03:39 PM
  #7200
Print mag or online?
Would love a copy of the article!
fritzzz is offline
