Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 12-05-2011, 10:03 AM
  #7021
Dasmopar's Avatar
Originally Posted by Jay7 View Post
Can you post your F104 Pro setup sheet as a reference starting point? I was told I can use Kimborough spur gears but they told me I need to use some type of spacer? Anyone know where to get the spacer? Trying to find the perfect rollout as i'm new to F1 and don't want to destroy a motor.
http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
Dasmopar is offline
Old 12-05-2011, 10:09 AM
  #7022
mattwoodcraft's Avatar
the kimorough spurs work a treat and you can put 12 diff balls in them and the diff works very well heaps better. im using a 2.5 fdr 88 spur 35 pinion with a 17.5 motor can drive around for 30 minuts and the motor is warm.
mattwoodcraft is offline
Old 12-05-2011, 11:42 PM
  #7023
Trader Rating: 19 (100%+)
You in town this weekend matt? If you're free we should go to the test track on Saturday... im racing whiteman park on sunday.
LordAnubis is offline
Old 12-06-2011, 03:11 AM
  #7024
Going to bite the bullet and order a F104 Vodafone McLaren Mercedes MP4-24
What else do people recommend I order?
58475 F104 Vodafone McLaren Mercedes MP4-24
http://www.stellamodels.com.hk/produ...oducts_id=5218
54215 Spur Gear Adapter (F104)
http://www.stellamodels.com.hk/produ...oducts_id=4594
54158 F104 Aluminum Diff Housing Set
http://www.stellamodels.com.hk/produ...oducts_id=4035
Batteries - do I need a rounded LiPo or will square fit?
I need a small ESC to go with the stock can?
Thanks for your help, can't wait to get onto it!
fritzzz is offline
Old 12-06-2011, 06:14 AM
  #7025
nrtv20's Avatar
What car has the better aerodynamics package? The Ferrari or McLaren?
nrtv20 is offline
Old 12-06-2011, 06:37 AM
  #7026
rcdave1's Avatar
Trader Rating: 14 (100%+)
If you are in the US take a look at tqrcracing.com they have 104's and parts in stock at good prices and fast shipping
rcdave1 is offline
Old 12-06-2011, 09:57 AM
  #7027
Dasmopar's Avatar
Rounded lipo fits better but both can be made to fit.
Dasmopar is offline
Old 12-06-2011, 10:27 AM
  #7028
Default Kimbro?
Deuce-Are these "Toledo F1 legal"?
aarcobra is offline
Old 12-06-2011, 11:03 AM
  #7029
Dasmopar's Avatar
Yes it is but I think we are all using the tamiya gears so far.
Dasmopar is offline
Old 12-06-2011, 11:35 AM
  #7030
Hello
i've got interesting problems, my suspension (two "classic" dampers, with no friction damper) works very well with my Tamya F104GT.... but i've got problems with steering.
I have on my controller EPA for steering: L: 30% R: 75%. And still everytime i turned left on the track it was too much, but on the right it was good..... i think this is not normal, do you have any suggestions? :-( P.S: i have 103GT front axle
SquirrelCZE is offline
Old 12-06-2011, 01:30 PM
  #7031
robk's Avatar
Trader Rating: 22 (100%+)
oil shock...
robk is offline
Old 12-06-2011, 02:15 PM
  #7032
Thanks but I am in Australia - will check out their shipping but things tend to be cheaper from Hong Kong
fritzzz is offline
Old 12-06-2011, 02:19 PM
  #7033
Originally Posted by robk View Post
oil shock...
Something like this one?
http://www.stellamodels.com.hk/produ...oducts_id=4176
fritzzz is offline
Old 12-06-2011, 04:22 PM
  #7034
thats the one
Old 12-07-2011, 10:43 AM
  #7035
al dente's Avatar
hey guys, i have an f104x1, love car but am having a problem. when i try to get on throttle coming out of a turn, the car diffs out..... i've tried tightening the diff to various different degrees, including all the way locked down, where the car just loops out on throttle. the car seems to be staying flat in the corners, and does not lift the tire. but it seems that just the slightest bit of traction loss to one side causes the diff to spin.
any thoughts or ideas?
al dente is offline
