Tamiya F104 Pro!
#6826
For a while there, guys were messing with the angle of the upper arm by adding shims to the inside rear ballstuds or removing the spacers under the camber plate in the front to get some caster and camber changes that promote more steering but, is the rear locked in enough to warrant more aggressive steering?
Baby steps I guess.
RobK has posted lots of different front end variables on his http://rcf1blog.blogspot.com/2011/02...front-end.html
This link takes you into the middle of his blog, you can navigate from there and see/learn lots of cool stuff. In case you haven't been there yet, that is.
Baby steps I guess.
this rcf1 blog is added to favourites for sure top suff !
#6827
#6830
Visit www.tamiyablog.com.
This is probably the new Tamiya F104WGP car, a hybrid between F103 front and F104X1. By looking at the chassis, it's replacing the side electronics holder with chassis plate.
#6832
I know this isn't the 104 I'm talking about but when i put an exo104 chassis on my 103rm my rear grip was improved over the stock friction plate system.
So much more confidence in the corners with the side damper setup.
Although i think the 103rm still works better on tighter tracks where you're less worried about losing the back end. I tend to get the nose around the corner and worry about the rear later with a touch of off power mid corner.
Also might be the shorter wheel base of the 103rm vs the exo that makes it better on tech tracks imo.
#6835
#6836
My ride. Tamiya 14T brushless. Car was swerving to the right under hard acceleration, so I separated the rear tplate w/ pod and balanced that left to right. Then balanced the entire car on scales.
That fixed the problem. Car now accelerates straight.
