Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 10-28-2011, 09:13 AM
  #6721
Pro10noob's Avatar
It is a bit easier for us to determin what kind of rollout you have to start with.
So how many turns motor?
Are you allowed to run timing?
Are you running rubber or foam?
What spurs and pinions do you have?
What is the track like?
Tech track? high speed track
All these questions have effect on how to use the Tekin.
regards Roy
Originally Posted by Shameless121
It's the tekin rs esc and tekin redline motor I'd need help with. And I'm hoping to race it in the uf1 winter series at TQ if that helps at all
Pro10noob is offline
Old 10-28-2011, 12:56 PM
  #6722
regards Roy
It's a 17.5 motor n/t on rubber tires, I believe stock gearing, high bite carpet track, fast open track,
Shameless121 is offline
Old 10-28-2011, 01:00 PM
  #6723
Pro10noob's Avatar
OK stock gearing.
Can or may you drive with timing or not?
regards Roy
Old 10-28-2011, 01:14 PM
  #6724
LMRacing's Avatar
Trader Rating: 27 (100%+)
I read the N/T as no timing.
Just picked up an F104 Pro on the for sale forum. Any suggested parts to keep in stock? It has a cracked Tbar plate, is the white fiberglass one the right part? I thought they came with a carbon fiber Tbar plate but I cant find a part number anywhere
LMRacing is offline
Old 10-28-2011, 01:26 PM
  #6725
Pro10noob's Avatar
Oops my mistake.
If you have to use the stock gears like the 104 and 93 spurs then start with a rollout of 45.
Temp the motor every 3 or 4 minutes to check it.
Never let the motor go about 70 degrees celcius as it tend to fade a bit and you loose a bit of brake and torq.
If it stays cold work your way up to rollout of 50(keep checking the temp)
We drive with a 23T brushed motor the same rollout on most tracks as starters and work our way from there.
If the motor is to powerfull out of the corners, give it a bit more mechanical timing so the rev's goes up and the torque a bit down.
This give you a bit more top speed but it drives better out of the corners.
Rubber on carpet i haven't got a clue with F1 as we drive foam.
It all depends if you have to use the Tamiya rubber or not.
regards Roy
Old 10-28-2011, 02:51 PM
  #6726
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Actually the UF1 guys run 21.5 not 17.5 blinky.
RedBullFiXX is offline
Old 10-28-2011, 02:54 PM
  #6727
robk's Avatar
Trader Rating: 22 (100%+)
Stock t plate is black fiberglass, but you want the greenish white one (soft).
robk is offline
Old 10-28-2011, 02:56 PM
  #6728
gashuffer's Avatar
Trader Rating: 48 (100%+)
I just bought some front ride wheels and tires for my 104 and both fronts are rubbing on the kingpins on the bottom at the c clip! Has anyone come across this issue? Sucks to have to grind away at a brand new set of wheel that are suppose to fit.
gashuffer is offline
Old 10-28-2011, 03:41 PM
  #6729
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Adjust the front ride height with the spacers and you should be fine.
PDR is offline
Old 10-28-2011, 06:15 PM
  #6730
Trader Rating: 19 (100%+)
Originally Posted by mr lee
Thanks for the feedback and findings with the new parts.
So you would agree that they are worth the $'s?
Strange that you say the heavy pivot post gave you no on power steering....well I suppose if you have too much rear traction you take away steering
Will be waiting to hear your feedback with the heavy pivot post removed.
Yeah Well worth the money... the roll damper is like 20 bucks anyway so who really cares !?!?!
I've jsut removed the heavy pivot post, gone back to the standard alloy one, and ive gone the softest front springs i could find. will see how it goes on Sunday.
LordAnubis is offline
Old 10-28-2011, 06:33 PM
  #6731
gashuffer's Avatar
For the money they should fit. Sacrificing a tuning option to get them to work is just not right. Trusty dremel to the rescue. Smoothed out ready to roll.
Old 10-29-2011, 12:06 PM
  #6732
Trader Rating: 38 (95%+)
hi, i have a pretty stupid question, but new to formula one cars, which wheels do i use to mount the sponge tires, all the tamiya wheels at my local hobby shop are for rubber tires, and having a hard time to find tires that will work with the sponge tires, please help, i bought the f104 x1, and sponge tires, i believe they are standard size and not the wide ones, thanks
zaraz is offline
Old 10-29-2011, 12:27 PM
  #6733
Pro10noob's Avatar
GP Speedtires sells a complete set, as in rim with foam glued and trued for the F104.
Exceed has them to i believe?
regards Roy
Old 10-30-2011, 03:27 AM
  #6734
Ok so i took out the heavy pivot post and the car runs AWESOME !!! on our track which id describe as medium grip bumpy ashphalt, and my ususal tamiya medium rears with tamiya hard front rubber tyres the car was awesome. I ususally do 22 second laps with the odd 21 second lap. Today i did consistent 21 seoncd laps with a few high 20 second laps in there as well...
I think the rolling damper adds some predictability to the car which allows you to improve your consistency.
Old 10-30-2011, 07:00 AM
  #6735
Registered User
Default Problems
Why does my f104 ferrari make sounds when i turn particularly right? It sounds like its coming from the spur gear and the pinion gear. Im using a 93 Spur Gear and a 30 Pinion Gear. I hit a wall and then it started to make the sound. I rebuilt the diff. Any Ideas?"?
wonderjew is offline
