Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 10-23-2011, 05:13 AM
  #6691
mattwoodcraft's Avatar
Originally Posted by aussierevo
i ran with the counterweight tonight on my F104 and didn't notice any real change to the car, but it does look good on the car
as long as it looks good
mattwoodcraft is offline
Old 10-23-2011, 07:43 AM
  #6692
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by theatriks
Hey guys quick question on gearing ....so I am running on carpet with a silver can ok....I had a 93 tooth spur with a 30 pinion on it for like 30 races and the motor lasted no problem ....I put the same gearing on a new silver can and the motor blew !! So I got another silver can and put a 104 spur with a 29 pinion and guys were faster then me running a 25 and a 104 but besides that my silver can running the 29/104 combo blew after one 5min run ???? I'm using a wolf pack 3000 batt with a tekin fx what combo should I put in there where I'm gonna be fast and not blow the motor ?
That is a lot of gear for a silvercan, especially if you are on rubber tires which have a large dia.
Normally you would gear a silvercan based on temp, buy a temp gun.
Try not to let it go over 200f, 150f is optimum after 5m.
10 to 15m runs with todays lipos are easy to do on the rug, but not so good for silvercans, maybe a practice motor & race motor is a good idea.
All silvercans are not the same, not even close to the same.
21.5 blinky is so much nicer.
RedBullFiXX is offline
Old 10-23-2011, 09:00 AM
  #6693
Trader Rating: 56 (100%+)
Default Hmm
I blew my silvercan last night, hit 200degrees and cooked the comm. Between the high traction and the foams wearing down, it was bound to happen. Car was super fast though lol. There is definatly a variability in the motors. With that said, what is a good conservative rollout to start with for silvercans? We are running on foams.
dynamic_e is offline
Old 10-24-2011, 04:27 AM
  #6694
Trader Rating: 19 (100%+)
Originally Posted by mattwoodcraft
i find even a 13.5 turn motor at times is way to much if i get trigger happy i get taily and is hard to use all the throttle. i will be putting my 17.5 turn back in for sure unless the track get a heap more traction
Don't be a pussy, when i save up the funds a 10.5t is going straight in !!!! I'mm gonan take off when i hit the elevated corner before the back straight.
Got my parts by the way... installing tonight/tomorrow and will be all set for sunday. You racing sunday?
LordAnubis is offline
Old 10-24-2011, 07:26 AM
  #6695
Installed.
F104Pro with pretty much every alloy hop up you can get for them... except alloy knuckles. This car has not missed a single beat. Running 3racing wing set, boosted 17.5 turn setup, tamiya wheels and tyres, 60g weights on each side pod, just installed heavy pivot post and rolling damper and split top deck. Also got the counter weight but have not installed yet.
And yes my front tyres are knackered :P
Watch out matt, im hunting you down next race !!
Old 10-24-2011, 09:00 AM
  #6696
F N CUDA's Avatar
Hey Lorddude,
Did you see the video of the IIC F1 race in Vegas?
You might wanna consider mounting your transponder up front cuz if Hiro had his back where you have yours he would have lost that spot, at least electronically.
I had a race go that way, I crossed the line in second but my transponder was up front and the other guy's was further back. We all knew he crossed first though but the computer saw it the other way.
F N CUDA is offline
Old 10-24-2011, 11:57 PM
  #6697
ok guys, this thread got me exited about f104 racing, so I'm reading up on the parts I need. I will order the f104x1 and some other stuff, but I'm in the dark about the tires. I want to run rubber only, so wich tires for indoor (carpet) and for outdoor (MACH Heemstede Netherlands). Tamiya, Pit, Ride, etc, etc?
For outside try Ride soft front-medium rear at high temperatures. At low temperatures or rain try supersoft front supersoft/soft rear. If you pick an 10.5T BL or below definitely try them.
ps: love your track by the way
jlask is offline
Old 10-25-2011, 12:14 AM
  #6698
Originally Posted by LordAnubis
Installed.
Attachment 824551
Attachment 824553
Attachment 824554
Attachment 824555
actually what is the purpose of adding 60g for both side ??? to make it more roll ??? will it becomes more oversteer if more roll ??? it's a bit comfuse.........
secondly, do we need to add more weight on radio side in order to compensate the ESC+wires(eg. 80g on radio and 60g on ESC) ???
thanks~~~
Marco926 is offline
Old 10-25-2011, 12:35 AM
  #6699
the weight gives the handling characteristics of an f103 where the weight is distributed along hte width of the chassis. It was recommended in this thread a few pages back, and it works really good at my track.
Balancing a car is overrated :P
Old 10-25-2011, 02:02 AM
  #6700
F N CUDA's Avatar
Tamiya's David Jun has even recommended putting weight up high in the airbox on the body of the F104, less weight up hi to get the same results as more weight down low.
Offroad buggies been adding weight to the top of their trans to get this effect too.
F N CUDA is offline
Old 10-25-2011, 04:59 AM
  #6701
thanks mate. i will be racing next time im home i hope my gear there waiting for me when i arrive home
i found the 17.5 motor easier to drive i could use the power better alothough the 13.5 is good
Old 10-25-2011, 08:22 AM
  #6702
Yeah i did read that by david jun but had no clue what he meant by the air box :P
Cheers for the transponder advice too, i'v always been wondering about it i jsut haven't bothered to move it :P
Old 10-25-2011, 08:24 AM
  #6703
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Nice screen name!
sg1 is offline
Old 10-25-2011, 05:33 PM
  #6704
Odin544's Avatar
Trader Rating: 93 (100%+)
Can someone help me out with the bearing sizes? I looked in the manual but it only shows part numbers. Thanks!!
Odin544 is offline
Old 10-25-2011, 05:49 PM
  #6705
The part number has the size in it ie BA1060 is a 10x6 bearing. In any case:
10x5x4 4 Bearings - Front Wheels
10x6x3 2 Bearings - Drive shaft
12x8x4 2 Bearings - Inside diff (only one needed if you dont run stock spur gear)
11x5x4 1 Bearing - Inside diff
