Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 10-03-2011, 07:55 AM
  #6496
connyw's Avatar
Will it be a complete x1 set for 104pro ?
connyw is offline
Old 10-03-2011, 11:36 AM
  #6497
robk's Avatar
Trader Rating: 22 (100%+)
They had listed part numbers, as in individual pieces. I would assume you have to buy each part separately.
robk is offline
Old 10-03-2011, 11:48 AM
  #6498
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Here's the Tamiya link to the X1 and it's hop up set which includes top deck, damper and damper mount $69, separate link has the axle counterweight $11.50.
Exotech complete chassis kit is only $120 and that's with an oil damper not greased "slider".
But if it's Tamiya legal you're after, here ya go
click the individual links on this page to see prices
http://www.tamiyausa.com/search.php?q=F104x1
F N CUDA is offline
Old 10-04-2011, 06:59 AM
  #6499
EEL Monster's Avatar
Really loving the F104! With a 13T HW EZRun the thing HONKS
Even though none of the clubs here race them, it's great to use when I can't use the nitro cars, and keeps my driving skills sharp
EEL Monster is offline
Old 10-05-2011, 03:57 AM
  #6500
Hi guys,
Just got back from Singapore, where I raced in the 2011 Tamiya Asia Cup Finals with my 10 year old daughter. Over 100 drivers from 8 countries. Just wanted to share my F104, which won concours. Hope you like it.
It was also pretty fast, 2nd on the podium
Photo credit: Marah Iskandar
Photo credit: rcblood.com
Thanks for viewing.
Attached Thumbnails Tamiya F104 Pro!-rc-car-tamiya-f104-concours-tac-2011.jpg   Tamiya F104 Pro!-tac-2011-f1-concours-winner.jpg   Tamiya F104 Pro!-tamiya-f104-concours-tac-2011.jpg
rccartips is offline
Old 10-05-2011, 04:28 AM
  #6501
mattwoodcraft's Avatar
awesome looking F1 mate
is there any vidio footage of the event ?
mattwoodcraft is offline
Old 10-05-2011, 08:45 AM
  #6502
LAPU-LAPU's Avatar
Trader Rating: 35 (97%+)
Go! Go! Go! Philippines!
@rccartips....congrats to you and to your daugther....and to the rest of the Team.
Nice looking car!
LAPU-LAPU is offline
Old 10-09-2011, 03:00 PM
  #6503
Mattwoodcraft, Lapu-Lapu, thanks.
Does anyone know how to build a smooth diff for the F104? Mine is sticky and crunchy. I'ver replaced the diff balls, sanded the diff plates, replaced the thrust bearing, used different grease and oil for the thrust bearing, used Associated stealth and tamiya ball diff grease on the diff balls... still no good.
Old 10-09-2011, 07:14 PM
  #6504
TryHard's Avatar
Ceramic balls in the diff?
I've built mine using the same old method I used on the TC's.
Sand rings with wet 600grit both sides (to make the plates flat), use ceramic Diff balls, and then use Schumacher diff greese.
Thrust wise, using the one-piece Tamiya thrust from the 103, and pack it full of AE black greese... and the Diff is pretty silky smooth IMO.
I did read on Rod's build of the X1 he had a gritty thrust, so could try replacing that.
TryHard is offline
Old 10-09-2011, 11:05 PM
  #6505
Pro10noob's Avatar
I used the one piece trust bearing from the F103 and ceramic diff balls.
It is silky smooth now.
Don't use a normall ballbearing as stated in the manual.
regards Roy
Pro10noob is offline
Old 10-10-2011, 08:30 AM
  #6506
MrChodes's Avatar
I don't know how, but I did it!
I assembled my third 104 diff a few days ago. I noticed once complete it was very smooth. All standard parts and Tamiya diff grease.
MrChodes is offline
Old 10-10-2011, 08:31 AM
  #6507
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Have you checked your axle bearings? They can affect the smoothness of the diff as well
BP SHADOW is offline
Old 10-11-2011, 02:01 AM
  #6508
could someone tell me the exact sizing of the 104 front wheel bearings and any place to get some.
thanks
freakyfreakyflo is offline
Old 10-11-2011, 02:14 AM
  #6509
Pro10noob's Avatar
LHS and the size is 5 inner 10 outer and 4 width
regards Roy
thanks
Old 10-11-2011, 02:23 AM
  #6510
regards Roy
many thanks roy. i buy packs from rcmart but only seem to use the front wheel bearings. i now have many diff and rear bearing and no front
