Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 09-30-2011, 12:37 AM
  #6481
Trader Rating: 19 (100%+)
Its not really F104 specific, but here's my F1's.
From left to right, Carpet F104, F201, Tarmac F104, F104 with F103 front and rear end, F104 with Exotek chassis kit.
I've got one more F201 with carbon everything sitting in a box too
LordAnubis is offline
Old 09-30-2011, 03:10 AM
  #6482
dfx
dfx's Avatar
Originally Posted by MikeR
You would trim the inside portion of the skirt to clear the side links like so. Not that noticeable.
Thanks! That sounds good. Maybe the body from Pro kit needs less trimming? I'm not sure which one is wider at the back. I will check that at home as I have that older McLaren too.
Mike is there any problem with sending Exotek stuff to Europe, Czech republic? Some shops do not send overseas ect.
dfx is offline
Old 09-30-2011, 03:21 AM
  #6483
tudor_47's Avatar
exotek in europe:
[email protected]
SF MODELLSPORT
Geesthachter Str. 58
21502 Geesthacht
Germany
[email protected]
Planet-RC GmbH
Bahnhofstr.2
CH-8592 Uttwil
Switzerland
www.dms-racing.com
in the UK
/johnny
tudor_47 is offline
Old 09-30-2011, 09:34 AM
  #6484
What is a good on the cheaper side though 21.5 brushless system? I have a novak xrs esc with silver can and it holds its own but I think ill need something more efficent in the long run. Also what is a good pack to run on the f104 pro?
one more question has anyone tried mounting the electronics in the rear of the chassis just behind the battery on the lower deck? I may try this to get the esc and reciever off the side. thanks guys
Shameless121 is offline
Old 09-30-2011, 11:15 AM
  #6485
CR0SS's Avatar
You cannot go wrong with the speed passion Cirtix system. $100 for motor and ESC is hard to beat.
CR0SS is offline
Old 09-30-2011, 11:20 AM
  #6486
notch johnson's Avatar
Shoot silvercan is hard enough for me to drive LOL
notch johnson is offline
Old 09-30-2011, 11:39 AM
  #6487
yeah I know silvercan is fast for me know with a 2 wheel drive and with little weight... Yikes soo i think i might throw a couple more aluminum pieces on it to help with breaking of plastic like motor mount r/l and also do the front and back wing mount from 3 racing. it will help heat and im able to mount a fan so it should help with heat. i also might create a mount for a fan directly in front of the motor near the pivot post to force air over the back.
Old 09-30-2011, 11:54 AM
  #6488
CR0SS's Avatar
Just cut out the air intake in the body over the driver's head. Then the air will go through the body over the motor.
CR0SS is offline
Old 09-30-2011, 03:38 PM
  #6489
texastc's Avatar
I bought a Hacker 21.5 from stormer for $39.99. Really smooth. But if you need esc/motor combo you can't beat the speed Passion.
texastc is offline
Old 09-30-2011, 05:04 PM
  #6490
Well I guess I'll have to get a new system because my Novak xrs esc isn't on the roar approved no timing list sucks
Old 10-01-2011, 04:47 AM
  #6491
mattwoodcraft's Avatar
i agree the citrix is a great combo i like the 13.5 turn i have 10.5 will try it out soon when the nationals start we have the F1 as a demo class this year at the nats
mattwoodcraft is offline
Old 10-01-2011, 04:59 AM
  #6492
k_bojar's Avatar
Trader Rating: 30 (100%+)
agreed - the cirtix is a great system for the $$!!
you can remove the fan (verified with solara) if running 21.5 or 25.5 motors - which makes the speedo fix better just make sure you pick up the programming box, so you can do some more fine-tuning (like brakes)
k_bojar is offline
Old 10-01-2011, 10:42 AM
  #6493
hi all
i'm new to the formula 1 chassis.
i came from 1:10 super stock touring.
is better the f104pro or the new f104x1?at the first sight the f104x1 seem and evolution of the basis f104.
hi and tnx
malekir is offline
Old 10-02-2011, 04:33 AM
  #6494
if you have not bought a F1 as yet get the F104X1 is better for rubber tyres
Old 10-03-2011, 03:31 AM
  #6495
....and if you already have a an F104pro, the additional and new parts that come with the X1 will be available towards the end of the year to the beginning of next year, so you can make it an X1
mr lee is offline
