Tamiya F104 Pro!
#6452
All the podium and A main cars were running wide F103 front and rear at the Tamiya EuroCup Finals last week. It is absolutely faster.
#6454
If your lucky on e-bay and if not try our beloved paintjob guru http://www.f1paintlab.com/Site/HOME.html
Send him a mail and he will hook you up.
regards Roy
regards Roy
The McLaren bodies are under the 104 section
#6459
http://www.exotekracing.com/f104-bolt-in-servo-mounts/
#6460
If you have a low-pro servo then this is the best way;
#6461
How much mm of shims do you use under the horn to space the ball stud down?
Also, do you move the servo back a little for good Ackerman.
I tried this setup the other week, and personally prefered Austin's upside upright servo to this method, but I don't think I got it setup well, so want to try it again.
Ed
#6462
Mike,
Ed
Ed
Yes, you can slide the servo forward or back as well to adjust ackerman. Bonus points for that
Here is Hayato Matsuzaki's car with the same set up;
#6463
I suggest 5-6mm of spacers (depends on your servo size) and the alloy horn. You want the turnbuckles perfectly level to eliminate the bump steer. Grind under the arms if they rub the turnbuckle when the suspension is compressed and the wheels are turned.
I used 6mm before, but I think I got the servo in the wrong place so screwed the ackerman up. Did notice the links getting close to the upper a-arms as well, will keep an eye on that.
On a different point, interesting that Hayato's car seems to be 1s... anyone know if that is a Japanese rule?
#6464
I'm surprised this is legal? In the UK at the BRCA the wide cars aren't allowed in the GP1 class (narrow,lipo + bl), although it appears nobody raced GP1 everyone ran in the GP2 class this year and ran Silver Can type + Wide cars.
I've considered trying the F104 front & rear on my F103 just to see how it handles in comparison before committing to buying a narrow car.
I'm quite intrigued by the Exotek FX10 conversion kit for the HPI.
#6465
