Tamiya F104 Pro!
#6406
It's not the type of kit that causes anything, the car just seems to need more weight if traction is not abnormally high.
#6407
The Tamiya track is not treated with any thing like sugar water, so traction is not as high. The track did get better since there were a lot of cars on it, and they seemed to rubber it up a bit. The asphalt looked like it was fine grain like a tennis court.
The track I usually race is low grip and unprepared, too. What I noticed is, that when I use NiMh akku they grain with a smoother surface than with lipo.Exactly the same as you got with adding weight.
Regards
Oortael
#6408
Hey Rob I noticed on your carpet set up sheet you got toe out on the front ....what advantage do u get from this because everyone else mostly runs toe in ...
#6410
#6411
A nostalgic F1 race at Tamiya track would be fun.
#6412
Pit F3 Med front 0574
R1 soft rear 0575
Gold front springs
1* camber
Ride height - all spacers on top of steering arm (lowest)
std. steering arm
30K diff oil on kingpin
shock 35wt/3 hole
tamiya blue mini car spring or short black set-blue
35wt side damper
CRC white side spring -just touching
~3mm pod droop -adjust to taste
#2 adjuster, turned up - lowest ride height
should be decent to start
R1 soft rear 0575
Gold front springs
1* camber
std. steering arm
shock 35wt/3 hole
35wt side damper
do you still using the thin insert from Pit for the rear tyre 0575 ???
i saw many said better use tamiya stock foam insert.....how is you comment on this ???
#6413
the acetone certainly makes a mess of the wheels broke a wheel on the new tyres i had on. I thought i would attempt to reuse the tyres but the blobs of plastic may make it hard
i tested the weights eather side of the the car like it was descussed here i have 40g each side not bad feels quiet a bit differant, i was testing with foams whick i dont like the feel of on the car i find it pushes way to much for my liking on asphalt
#6418
#6419
Well pooey...
Stripped my X1 down last night as something to do, and discovered that the lovely black alloy rear bulkheads are bent to buggery, which may explain the interesting handling from the other weekend. Have a feeling it may have happened when getting assualted by a touring car during practise.
Anyway, been looking around, and seem all the stock of black bulkheads are out of stock in my usual haunts... Anyone know where I might be able to find a set?
On another point, reading a lot more info on here, I'm getting an idea of where I was going wrong with the foam tyre setup, so somethings to try when I can get around to it (although time to concentrate on rubbers soon anyway with an indoor series coming up)
Ed
Ed
