Tamiya F104 Pro!
#6227
What's the biggest pinion you can mount and which ones make sense for rubber and foam on asphalt? I use the alloy motor mount.
#6228
pinion gearing will be dependant on what spur gear you are running and what you are gearing for how big is sthe track you are running on. to start with i was running a 25 pinion with a 93 spur but now i am running a 30 pinion with a 88 spur but our track has long straights and im mrunning a 13.5 turn
#6229
I use the 93 spur which came with the kit. What spurs do you use?
#6231
Some pictures of my latest shell all up and painted.... even in my biased opinion, it looks ace. Love the metallic blue... and well, Alesi!
(For those who don't know, it's Prost GP AP04 from 2001... the winter testing king... albeit it massively underweight!
Oh, and I got a little arty with the camera... so easy to do with these cars!
#6232
#6235
#6236
My Nimh has 390 g.
#6238
I'am going to make ProstGP bodyshell too, with Tomas Enge decals (the first and only czech driver in formula one), but can't find appropriate lexan body. maybe this one ... http://d-drivesportsenglish.com/inde...products_id=46
#6239
Thanks for the replies , I have fitted an old 5000/40c pack, weighing 290g approx.
The one I took out was only 230grams, so this on its own should help get some weight into it. I only have the std plastic pod etc, so the back is very light. My plan is to add some weight to the sides of the battery , near the rear of the lower deck.
My hope is to help get some more of the ponies to the ground, since I have plenty on tap.
#6240
This was an effort to resemble the F103 cross chassis battery mounting position and we all know the F103 kicks the F104's ass.
