Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree12Likes
Tamiya F104 Pro!
Old 08-09-2011, 08:14 AM
  #5971
connyw's Avatar
where can you buy 3racing F60 wing for 104
connyw is offline
Old 08-09-2011, 08:19 AM
  #5972
TryHard's Avatar
Originally Posted by rtypec View Post
Hi Ed. Yes, I was using Tamiya damper greases.
Cheers Rod, just picked up all three types, so gives me a good starting point
(and apologies for all the questions!
TryHard is offline
Old 08-09-2011, 08:21 AM
  #5973
connyw's Avatar
Originally Posted by alan1467 View Post
Used them for a few races and good
I understand when you use this T-bar
Then remove the lower original black support
Is this true ?
connyw is offline
Old 08-09-2011, 12:49 PM
  #5974
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by clayrace24 View Post
I have a couple of packs for my F1. Been using a 4000mah 25C pack that weighs 7.71 ounces. I also have a little higher quality pack that is 4000mah 35C and weighs 8.68 ounces. Can a 21.5 motor take advantage of the differance of the higher C rating, or would I be better off running the lighter pack?
Clay
C rating is a non factor, avg. voltage and IR are most important. Even more important, if you have a high traction situation or are at least using hooked up tires, the lighter pack will be faster.
robk is offline
Old 08-09-2011, 01:56 PM
  #5975
superspeed's Avatar
Can the motor and speed control handle higher C rating? 4000mah x 25C = 100 amps, max load. weight is going to make a bigger difference than higher c.
superspeed is offline
Old 08-09-2011, 02:03 PM
  #5976
C rating will not affect the motor or ESC...That rating gives you information on the maximum charge/discharge rate the battery can safely handle...not the amount of amps it will push through the motor/esc. The only way there would be an issue there is if the motor/esc were capable of pulling more amps than the battery can handle.
InspGadgt is offline
Old 08-09-2011, 06:57 PM
  #5977
cheROK1212's Avatar
Hey Ed,
Unscrew your damper linkage maybe 2 1/2 turns to give you some droop and some more rear traction hopefully.
cheROK1212 is offline
Old 08-09-2011, 08:06 PM
  #5978
TryHard's Avatar
Originally Posted by cheROK1212 View Post
Hey Ed,
hmm, thats a good point... whats a good damper length to run? I built it as kit (I think with the ball end tight) so guess it does need unscrewing a bit. There's a bit of droop at the moment, but not a lot.
Cheers
Ed
TryHard is offline
Old 08-09-2011, 10:44 PM
  #5979
gsxr0311's Avatar
Trader Rating: 19 (100%+)
rcmart.com, but unfortunately they are out of stock. check ebay.com
http://www.rcmart.com/catalog/rc-f10...h=595_744_1390
gsxr0311 is offline
Old 08-10-2011, 12:12 AM
  #5980
alan1467's Avatar
Is this true ?
Yes it replaces the plastic bottom section
alan1467 is offline
Old 08-10-2011, 01:19 AM
  #5981
mattwoodcraft's Avatar
i like the look of the 3 racing rear diff user that attaches to the bottem of the wing more so than the moulded one, i have been using the 3 racing wing set for a while now and is very good. the front wing is quiet soft has a bit of flex but hast caused me much a problem
mattwoodcraft is offline
Old 08-10-2011, 05:52 AM
  #5982
TryHard's Avatar
thought I'd post some picks of my X1 up.
Firstly, excuse the yellow wire (although I don't think it goes too badly with the gold anodising), but it was the thinnest the shop had! I've got some black 16AWG on the way for the motor to limit pod infulence, but I'm tempted to keep the power wires yellow....
Other points... yes, I've got a big square LiPo in there, so have the pain of having to take off the top deck to get it in and out. What I have done is mount in all the posts, but at the moment only use the two forward most holes. Also, where I've got the heavy pivot post fitted, I've removed the spacers, and replaced with alloy ones so I can use a nut to lock the screws in place
Battery movement forward is stopped by a small piece of cut of plastic servo taped to the chassis, and the ESC and reciver mounts, which placed on the posts, and servo taped to the cells... Does mean I can shift the cells a long way forward if required for balance.
Only other thing I did (as I really didn't like it!) was remove some material from the top of the ESC/Reciever mounts, so the O-ring sits just under flush on the post, so as not to apply any pressure to the top deck.
Otherwise, thats it... roll on this weekend to try some more bits out!
Ed
Attached Thumbnails Tamiya F104 Pro!-f104x1-sert-2-011.jpg   Tamiya F104 Pro!-f104x1-sert-2-002.jpg   Tamiya F104 Pro!-f104x1-sert-2-005.jpg   Tamiya F104 Pro!-f104x1-sert-2-006.jpg   Tamiya F104 Pro!-f104x1-sert-2-008.jpg
TryHard is offline
Old 08-10-2011, 07:47 AM
  #5983
Pro10noob's Avatar
Any one knows if the F104W bodies will be sold seperately?
Looking for one as i just recieved my F104Pro today.
Or are there other bodies out there that have the looks of the "old" F1 cars like the Mclaren MP4/6?
regards Roy
Pro10noob is offline
Old 08-10-2011, 12:26 PM
  #5984
connyw's Avatar
Do 103 rear wing fit on 104 ?
connyw is offline
Old 08-10-2011, 12:29 PM
  #5985
Pro10noob's Avatar
Yes they do.
regards Roy
