Tamiya F104 Pro!
#5866
Hi All,
Here's the video from yesterday's and today's runs with the F104 X1. For the most part, the videos are unedited. However, I had to cut a bunch out to fit my youtube video length limit.
Thanks to Kevin, Mark, and Brian for filming.
Not exactly dialed out of the box, but it is certainly a work in progress. I need to digest info gathered from yesterday's and today's setup changes and sort out what I'll try next week. Hmm...need to figure this out.
+ YouTube Video | |
#5869
Actually the matt black F60 is mine. I used Tamiya PS-55 Flat Clear (matte finish over coat for lexan)
Here's a link.
http://www.tamiya.com/english/produc...lear/index.htm
Here's a link.
Anyway, I think I've settled on a early '90's Ferrari scheme for mine when it arrives (a bit boring, but well, the shop didn't have all the paints, haha!) so red with black wings...
I'll save the pucker job for my painter... he won't know whats hit him.. haha!
Cheers
Ed
#5870
which is the largest rear wing to suit scale according to the F104
To get the most downforce rear
#5871
In all seriousness, it depends on the body that you're running. If you're using one of the older bodies, then you might want to look into the wings from a Lotus 107B...the front and rear wings have the most downforce out of all of Tamiya's one piece wings. If you want to go even further with a rear wing, you can use the wing from the Ferrari 412. You can adjust the angle of the wing to the point where it is nearly vertical, stalls out, and becomes a barn door dragging down the straight...
...but then again, I don't know.
#5873
Anyone looked over the TRG site recently?
Brabham BT45B shell for the F104W.
Looks awesome
Looks awesome
#5874
#5875
couple of pages back i discussed my own aero mods. started by adding 1/4 inch lip to the rear wing. the extra downforce was noticed as the car gained understeer in high speed slalom. This prompted me to add front downforce by making a mini front difuser. now it tries to spin out on high speed slalom.
#5876
I honestly did not notice the counter weight on the car. I was primarily concerned about directional stability (quick left/right transitions) and rear traction from mid to corner exit while getting on the throttle. Rear tires seem to have excellenct side and forward bite...but not both at the same time
need to work on that.
i remeber reading some where that some people use the F103 steering hubs is this to make steering smoother and not so aggressive
#5877
How do you know?
Can I ask where you might have come across that rear wing for the Lotus 107b. I'm in the process of building one up, and the wing that is similiar from TRG is a little too wide for my liking.
Cheers
#5878
I believe those are the 3.5mm offset steering uprights. I put a set of those as well as the heavy weight post on this morning. I have never tried the offset steering uprights on an F104 before, so it'll be interesting to see if they work as intended.
#5880
Hi Korey, mine has the same feeling. Understeer going in and through the first third of the corner with the front really never taking a set unless I trail brake and while others drove the car, I watched it at track level and seemed like the front end just washes out at times. I was trail braking to tighten up certain corners in the later half of the video I posted. I tried gold springs and it helped a little bit. Also adding front camber helped...but not as much as I hoped. I'm okay with understeer going in because I can correct it with braking, but once I figure out how to plant the rear end on exit, I will start playing with the front end (ride height, springs, dampening grease, geometries, etc.). I've heard of people putting weight up front but I'll use that as a last resort hehe
