Tamiya F104 Pro!
#5806
Im thinking more along the lines of the F60 as a base for the brawn Rep an then do a Senna rep Mclaren after would the stuff i listed fit or are you limited to what you can fit in these cars as i cant imagen theres much room inside
#5807
if you have big electronics i can say that pretty much anything will fit in the mp4/6. im runing some ancient ESCs that are gigantic on mine.
#5808
The kit comes with a carbon reinforced plastic parts tree for the motor pod pieces. It's light and the material is top notch. Unfortunately, the aluminum side plates are not included in the kit.
#5810
#5812
That pretty much covers the assembly of the chassis. With the exception of a few minor pieces, the car is very close to being finished.
I hope this build has been informative and I thank you for taking the time to view it. If you have any questions or comments, please let me know.
#5814
Why not do it properly, all the correct parts are available. Get the Speedway Pal Brawn bodyshell and 3racing wings, add the correct wheel covers to complete the look. Just don't know why they have never made the wings in white.
#5817
did you make sure the diff gear is in the right side? its asymetrical so if you put it on backwards it sticks out more.
#5820
Does this mean a return of Vyger to the track destroying everything in it's path?
Some say that the movie was a documentary, and that Star Wars was challenging to shoot because of less gravity.
